ATA 190 with FAX pass throgh
Suchi
HI
I have setup faxes with ATA , below is the call flow
ATA--UCM--SIP TRUNK--CUBE---SIP TRUNK---ITSP
my ITSP doesn't support t.38 , so i configured fax pass throgh, but most of the time faxes fail, any suggestion?
fax rate disable
fax nsf 000000
fax protocol pass-through g711alaw
remove fax nsf command and test.
Also, share debug ccsip mess for failed fax call
HI Mohammed,
Thanks for the suggestion & what is the impact if i use fax  protocol none?
No fax pass-through is attempted which you don't want. You need it to pass through
