ATA 191 Setting IP address via IVR
JAtest
Recently bought ATA 191 and attempting to provision the ip address via the IVR to that I can get web access via a PC.
I use the codes (111) to program the address after setting it to static (101). It says saved. When I listen to the IP address it says 0.0.0.0 and I cannot ping it from pc.
FaisalAhmed519
I have the exact same problem, unable to find the solution, please advise if you found any solution for this one.
