06-25-2008 12:23 AM - edited 03-15-2019 11:30 AM
customer having Call Manager for thier IPT services. He want to use ATA for fax, need to integrate with Call manager (CUCM6-BE).
Please suggest me license option , which is required here. Here i m finding 3 option for license (SW-CCM-UL-ANA, SW-SMH-UL-ATA-1P, SW-CCME-UL-ANA).
Please suggest me the license require for ATA, used for fax.
Manoj
06-25-2008 04:19 AM
Those licenses you listed are for 4.x or 3.x trains of CCM. You will need to get 1 DLU per ATA. You can order LIC-CM-DL-1 (times the number of ATAs)
08-26-2009 01:32 AM
Using the dynamic configuration tool there is a configuration error & one license should be selected. Can we just ignore the error & add LIC-CM-DL-1 instead.
08-26-2009 04:59 AM
Hi Khaled ,
Sure, just add one of these per ATA or LIC-CM-DL-10 if you had 10 ATA's. It's always good to have extra licenses moving forward anyways :)
Cheers!
Rob
