Attendant Console Enterprise vs. Standard
Scott Hanson
Level 3
Level 3
Enterprise is installed.  Any major pros or cons either way?  About 10 operators in total
Thanks in advance
Replies rated.
Jaime Valencia
The old versions like CUBAC, CUDAC, CUEAC only go as far as 9.x, there was no standard option.
10.x+ collapsed all into the Advanced and Standard option only.
In 10.x in short, all previous 9.x versions turned into CUACA, and CUACS is the new option, which is serverless.
I'd suggest you review the data sheet and install/configuration guide as they have all the details of the features, and then come if you have specific questions.
java
if this helps, please rate
