Attendant Console Software download
Scott Hanson
Level 3
Level 3
does anyone know a place where I can download the Attendant Console installation software any place other than the link below?
http://cisco-ac.arcsolutions.com/UserWebSite/cisco/Engineers/ciscoDownloads.aspx
All replies rated.
Thanks in advance!
Jaime Valencia
That's the official site to get the Cisco AC's www.cisco.com/go/ac, why do you want to download them  from other site?
java
if this helps, please rate
Not applicable
Hi, I have also been searching around Cisco for the download link.
I'm not keen that the site as it uses http for login details.
I have confirmed that you will need to register on the site for new login credentials. They will email you with a randomly generated password. Now I'm not so worried about logging into it.
Username does not need to match the one used for Cisco login (but I did use the same email address).
I can confirm I am able to download Cisco Unified Attendant Console from that link after registration.
