02-19-2011 03:46 AM - edited 03-16-2019 03:33 AM
HI all
i need assistance for selecting correct auto attendant console edition (business edition or deparment edition i have 320 phones and need two operator consoles ) . How do i order no of console required . ?
Solved! Go to Solution.
02-19-2011 05:20 AM
Business attendat console supports upto 6 operators and 500 IP phones while department console supports upto 2 operators and 150 IP phones.
As per your requirement, you should go ahead with Business attendant console.
Check the ordering information from the below link.
Hope it helps!
Please rate!
02-19-2011 05:20 AM
Hope it helps!
Please rate!
02-19-2011 10:01 AM
thanks .
this is what i was looking for.
