Attendant Consoles
voiceguy65
My company has been in the process of upgrading CUCM to 8.6.  However I just learned I am losing my free Cisco attendant console.  I am looking for something to replace it with.  I have not heard good things about Arc, or the ease of implementation.  I know there are some third party solutions out there and was wondering if any of you guys had any experience with them and could recommend anything.
Thanks in advance,
Allen
Take a look at this post, https://supportforums.cisco.com/thread/2172296
Please remember to rate all useful posts.
Response Signature
Response Signature
s_mcnally
I use IQ Solutions Vista Point console.  http://www.iqnetsolutions.com/Cisco_Main.aspx
Its simple for the end users to use, but updating the BLFs can be a bit of administration pain if you have regular changes.  Company is great to work with from a support aspect.
voiceguy65
Thanks for the suggestion roger, seems like a lot of positive regarding Fidelus, its nice I dont need a server!!  I have downloaded their trial and will be taking that for a spin.
S_Mcnally, thanks for the recommendation.  I will be running a trial of Iq net as well.
More to come as I test.
Thanks again,
Allen
Guys thanks for all your help.
I have been strongly leaning towards and most likely will purchase the Fidelus solution.  After evaluating each, I have found theirs to be the easiest.  Support was good as they were able to help me w/ a few questions.  Definately would recommend them to anyone else with my same problem.
Thanks again guys!
Allen
