Authenticating phone via EAP-TLS
Nadav
Level 7
Level 7
Hi everyone,
I'm trying to authenticate deskphones (LSC certs, not MIC) via EAP-TLS. I'm using the latest version of Radiator AAA server. I've read on the forum how this is done for phones which authenticate with a MIC, but I'm interested in the more secure LSC solution. My cluster is in mixed mode and each phone has an LSC installed.
As part of the configuration I need to supply the public and private key for the server authentication. I'm assuming the CAPF-trust certificate called  CAPF-xxxxxxxx.pem is the public key (I took the one which appears under every phone's security menu). Anyone know how to extract the private key?
Better yet, can anyone provide a snippet of radiator configuration for authenticating with LSC?
Thanks for the help :)
Did you use self-signed certificate for CAPF or you installed signed one.
Created via CTL client and two SASTs to sign it, so it should be self-signed.
If I were to take a SAST and use Safenet utility used for the CTL client, would the exported certificate be the server's private key? Would I need all such certificates from the SASTs for EAP-TLS?
Nadav
Level 7
Level 7
Does anyone have any idea how to extract the private keys of the CAPF (which was installed via CTL client)?
Nadav
Level 7
Level 7
With some trial and error I've found how to configure Radiator to authenticate by EAP-TLS with LSC certificates. Below is the relevant handler for 78xx series phones:
<Handler User-Name = /^CP-78/>
<AuthBy FILE>
Filename %{GlobalVar:MY_DIRECTORY}/users
EAPType TLS
EAPTLS_Protocols TLSv1,TLSv1.1,TLSv1.2
EAPTLS_CAPath %{GlobalVar:CERT_DIRECTORY}
EAPTLS_CAFile %{GlobalVar:CISCO_CAPF_FILE}
EAPTLS_CertificateFile %{GlobalVar:RADIATOR_SERVER_CERT}
EAPTLS_PrivateKeyFile %{GlobalVar:RADIATOR_SERVER_CERT}
EAPTLS_PrivateKeyPassword mypassword
EAPTLS_CertificateType PEM
#You can choose either to allow session resumption or disallow it
EAPTLS_SessionResumption 1
EAPTLS_Ciphers HIGH
EAPTLS_MaxFragmentSize 1500
</AuthBy>
</Handler>
Keep in mind that there are two certificates on the radiator side: one of which is the CAPF file which can be obtained from Certificate Management under the CUCM, and the other is a local certificate with a private key. Both certificates should be in the same directory.
