02-06-2008 08:56 AM - edited 03-15-2019 08:39 AM
I have implemented a work around for paging over the phones. Basically, in strategic locations I have set up phones with a new DN set to auto answer.
It has been brought to my attention that people are abusing this and using it to evesdrop. Is there a way to set up the auto anser extesnion to auto answer on mute? 4.1.3
02-06-2008 10:13 AM
I don't believe there is a way to actually mute the phone but you can increase the timeout value so the speaker phone takes longer to go off hook in either enterprise or service parameters.
02-07-2008 10:13 PM
AFAIK it cannot be done, the mute enable/disable is not configurable from CCM, but from the phone itself (you need to press the button)
