Auto attendant Cisco
mbelfortas
i have call manager 7, and unity 5.x, and ip phone 7965 configured and up
i have 04 line RTC, i would like to configur them in these 7965 like standard office
with welcom message, and auto tranfering call in intra office lines.
line intra of 7965 (5000,5001,5002) receive call call from externall, welcome message after automatic operator to transfer call to lines office
how i can do that if it is possible?
how i can config one line of standar as fax line?
thanks
Dan Lukes
Moved to more appropriate community (your question is unrelated to Small Business kind of product).
Jaime Valencia
Yes, there are plenty of threads on how to configure AA, most of them now will refer to CUC, but it's very similar in Unity
http://docwiki.cisco.com/wiki/CUC_FAQ#How_to_create_a_simple_AA.3F.3F
FAX will depend on the procotol you use, and what you use for PSTN. cisco.com has a lot of material on fax configuration, once you know which protocol you want to use, you can search for reference material.
java
if this helps, please rate
