IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5797 Views
  • 14 replies
Hi , I have facing some problem for IP Telephony system. When I have call from outside on IP Telephony system like "+8809610127777" then DTMF and IVR tone working fine But after I have dial extension number  like "520" but call not transfer this exte...
Resolved! CUCM Router Filter
Hello I'm working in a Dial Plan design but the used of route filter is require from mark local calls and long distance calls, but the route filter architecture is kind of complicated, there's a way for used Globalized Dial Plan for avoiding using R...
ychristo by Level 1
  • 298 Views
  • 1 replies
We have a smaller site we support with an aging call manager, recently a new firewall was installed which caused some issues. At this time however we can talk to the networks, all IPs ping each other but we cannot get the GUI to load for CME or CUE. ...
Hello All, I has been updated a cluster from 6.1x to 9.1.x, after doing MGCP gateway working fine technically but the gateway page shows  IP Address "unknown" , i am not sure either it is  a bug or any cosmetic issue.  I am attaching the snapshots as...
Dears, please describe this SIP Profile,sip-ua retry invite 3 retry notify 6 retry register 10 timers connect 1000 timers notify 100 registrar ipv4:192.168.126.1 expires 3600 sip-server ipv4:192.168.126.1 notify telephone-event max-duration 200 host...
Hello, I'm facing issue in outgoing calls, incomming calls working fine. Outgoing calls choose correct dial-peer and interface but ITSP don't receive any call on that SIP Trunk. They receive a call from another SIP Trunk that's terminate on same VG....
