Auto Attendant of Cisco 4321
License
Dear Experts,
We have a 4321 router with CME setup. It is ordered with only 4GB RAM and 4GB Flash. Now I need to setup the auto attendant on this router. I tried Cisco BACD which is not at stable ( Some times play prompt some times not). We would like to have CUE virtual on this router. What are the part numbers for RAM & Flash upgrade, and the mSATA SSD?
Your kind support will help me a lot
Thank You all
License
Is the below part compatible with Cisco 4321?
UCS-EN140N-M2/K9=
Jaime Valencia
If you're a Cisco partner, you should be reaching out to pre-sales for ordering/PN assistance.
If you're an end customer, you should be reaching to a Cisco partner with UC specializations or a distributor for assistance with this.
java
if this helps, please rate
Ratheesh Kumar
HI there
Following Jaime's note, you can also go thru these documents
Cisco Unity Express Compatibility Matrix
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.html
Unified CME 12.6 Supported Firmware, Platforms, Memory, and Voice Products
