03-17-2015 01:42 PM - edited 03-17-2019 02:21 AM
I currently have CUCM 10.5 setup to auto register phones and I use Cisco prime provisioning 10.5 to auto provision the users.
Self provisioning is setup and users can call the IVR number enter the self service ID, which is their DN.
what I would like to do is send an email notifying the end user of their setup and how to use their telephony device Example (Self-service ID: 8888, auth code: 3333) is this possible from Prime Provisioning or CUCM.
Solved! Go to Solution.
03-17-2015 04:53 PM
On CUCM I'm sure there's no such thing, and AFAIK Prime Provisioning doesn't have anything like that either, you would need to use your own email system to distribute that info.
03-17-2015 04:53 PM
03-17-2015 05:47 PM
Thanks Jamie
Wishful thinking I guess. It would have been seamless if they added that form of email notification to end users when auto provisioning. Anyways to get around that I used MS word mail merge and used the same spread sheet I used to batch provision the users to send the Self-service ID to the email contacts.
