02-10-2015 01:28 PM - edited 03-17-2019 01:55 AM
Hello All,
Just need a quick verification on the auto qos voip trust command. I am using it to try and prioritize traffic coming from an SBC going to the ITSP. We have a 4948-10G switch sitting between the two.
SBC -----> 4948 --------> ITSP
The SBC is sitting on port 1/19
When I run auto qos it puts an outbound policy on the interfaces that looks like it is putting priority traffic into tx-queue 3, giving it 15% of the bandwidth and shaping the traffic to 15%. (I changed values from 33%).
My question is ... is this sufficient to at least prioritize VoIP traffic as it traverses the 4948 switch?
I have included the config for reference.
Thank you for any and all help.
Solved! Go to Solution.
02-10-2015 05:06 PM
Since its going through a Gig interface and you have configured 33% of the interface bandwidth i.e 330Mb for the priority traffic/voice calls, before it starts shaping on this switch.
I would guess this is more than enough for the voice calls but in the end depends on your environment (enterprise, SP/Re-seller etc.). You can just compare with the SIP channels/Call package you have bought and compare if this bandwidth is sufficient to run at full capacity. (BW you would need for your all SIP calls = Number of maximum calls x BW per call depending on codec G711/G729)
-Terry
02-10-2015 05:06 PM
-Terry
