Hi All, I have a question on 8841 phone with CUCM 10.5, when I call any number it is suffixing server name like XXXX@<servername and it is showing on 8841 calling party phone. Where can I make changes so that I can see only number
Folks, I have 8851 phones configured on CME 10.5 using latest firmware, 10-2-2. For the Call History, the "Recents" button isn't showing and apparently, according to the Admin Guide for the phone on CUCM, this feature is disabled by default. See bel...
I cannot get cellular calls to Sao Paulo to go through. Any insight would be appreciated. ! dial-peer voice 191 pots description Emergency Calling destination-pattern 19. port 0/0/0:1 forward-digits 3 ! dial-peer voice 9191 pots description Eme...
I'm going to make a test with the new CP-8811 desk phone, I downloaded the 8811 upgrade ".sgn" file and upgrade it to CUCM 8.5, but I can not find the 88xx series from the device list, I also tried version 9.1 and latest 10.5, unfortunately, 8811 sti...
I implemented Mobile Connect in our infrastructure. I successfully created 4 remote destination profile. While creating the 5th profile, I am unable to see the "User ID" in the drop down list. I looked in "End User" and the user is created. How do I ...
.Hii would like to add phones 7861 to cucm 9.1 but i didn't find this type on the listecould you give me please the packege needed to add this phones (download link)CUCM version is : 9.1.2.10000-28
Hi,I am currently running CUCM 7.1.5.33900-10Due to geographic change within one of our sites I need to change the Primary router entry in a DHCP subnet. Is it simple a case of making the change, saving it and rebooting the phones or do I also have ...
Hi, I know that many years ago the questions was asked but I want to know if now Cisco have a Cisco ip phone model who's sealed and are water resistent. We need to install some phone in food laboratories and might be splashed with water when we clean...
Hi,I am pretty sure there should be a way to hide the cucilync window, our customer does not want to have two different windows.Any idea?Thanks,HM
We recently upgraded to 10.5.1 and since then we are having issues with the message indicator on handsets.When a voice message is left, the light usually comes on the handset (most of the time). When the message is listened too either on the handset ...
Hi All,Can we have one dspfarm profile for audio and video?? I created one for video and after that it was not allowing me to configure one for audio.I was getting a message "no resources" Any help is much appreciated. Thanks
All, I am trying to configure extension mobility in 10.5, I did configure phone services but I don't see that when I go to phone to subscriber it.Do you guys think if I am missing anything? Tha
Hello, My customer has initially done a CUCM Upgrade from Version 6.1.2 to version 8.5 (both on MCS Server Platform). Now they want to move to version 9.X or 10.x, but they done have a valid UCSS. And I also understand that the UCSS and ESW have bee...
Hello I am new to call managers and was wanting to check if there are any place to check if a particular extension say 1234 is hitting the call manager. sorry if this a basic question but would be grateful to have some advise on this. thanks in advan...
Hi I currently have a destination number set for my call forward no answer external but any call from an external number to the internal network fails to apply the call forward. when i FORWARD ALL to the same destination number the call seems to have...
| Subject | Author | Posted |
| 12-31-2025 01:52 PM | ||
| 12-10-2025 11:24 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM |
