ā05-26-2013 03:37 PM - edited ā03-16-2019 05:31 PM
Hi everybody.
CUCM---Sw----Ipphone (7940)
Above CUCM controls our phone. It is also running tftp service.
We want our 7940 phone to auto-register with CUCM upon boot up.
Assuming we successfully set up our cucm for auto-config, what will happen next? Will config files will be generated? what will those files?
If i change the parameters while configuring auto-set up such as load , device pool, will these changes also change the load info and CM list in configuration files ?
thanks and have a geat day.
Solved! Go to Solution.
ā05-26-2013 04:32 PM
Hi Sara,
Below the informtion requested:
Will config files will be generated? Yes
what will those files? Files will be request by the phone
If i change the parameters while configuring auto-set up such as load , device pool, will these changes also change the load info and CM list in configuration files ? Yes
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas Ćŗtiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
Hi Sara,
