05-06-2009 04:37 AM - edited 03-15-2019 05:52 PM
hi
i configured attendant console with pilot point and hunt memmbers.
then i connncted my console pc through one extesion,calls are passing thru pilot point to members.but icant see anything related to pilot point transfer friom my console.
i should be able to see the calls comign to pilot point from console ,right?
please help..
05-06-2009 04:47 AM
NO, you only see your lines in AC client
java
if this helps, please rate
05-06-2009 06:56 AM
hi
so ,if i am a receptionist and i want to see the calls coming to pilot point and to manage from console,its not possible?
only the calls associated to my phone can be manipulated with this console,right?
please...
05-06-2009 07:10 AM
i guess you don't understand how AC works
calls arrive at pilot point and are sent to the members of hunt group.
pilot point is a virtual number
Read this doc to understand the way AC works
Cisco Unified Communications Manager Attendant Console
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmfeat/fsccmac.html
java
05-14-2009 06:23 AM
Hi Java
Hope you are OK.
Please let me know if I can use the AC user that is created in a shared active directory for all CUCM clusters. Currently one of the CUCM cluster is using the AC user for a console, but I want to use this AC user to other CUCM cluster's user.
Is possible?
Version 4.1.3
Andres
05-14-2009 08:34 AM
Doing fine, thx.
Hope you're OK as well.
There should be no problem with this, you can also create different users per site so you can manage this independently and avoid having just 1 point of failure for all clusters.
Q. How do I change the Attendant Console username and password for JTAPI applications?
http://www.cisco.com/en/US/products/ps7282/products_qanda_item09186a00800b0a20.shtml#qa23a
java
