AXIS ip video Camera Door phoen on 797X
blackmichael
I am trying to setup a an Axis Video Camera to display on a 7970 / 7971 phone. I have seen this done. I am trying to do this for a door video phone. Can anyone point me in the right direction to make this work. Please share what you have done.
5 Replies 5
paolo bevilacqua
unless you are willing to write yourself all the required component using the public "phone services SDK", the way to do that is with third-party products, e.g for ipcelerate, AND,
http://www.andtek.com/communications-products-observer.html
stefan.ziem
Do you found a solution to implement this?
A customer want the same setup he has seen at the cisco office.
I want to connect the door opening system via ATA and additional the Axis video on the phone screen.
No i have not found a solution.
Hide a laptop behind the wall running VT advantage. When they make a call to the front desk, VT Advantage will auto pop and show video call.
(jokes about the laptop behind the wall, but something similar)
The problem is VT will not push video on the phone screen and this feature is requested.
