Backup CUCM 10.5 via SFTP using ssh-key
bagnolini
Hey guys,
I would like to backup my CUCM 10.5 using SSH pre-shared key. Is it possible?
Anas Abueideh
Level 9
Level 9
the question is not clear. can you give more info ?
normal backup is done through SFTP network location from disaster recovery page
Anas
don't forget to rate the helpful posts
Hi.
No.
Backup device, on DRS, requires Username and Password.
Carlo
Please rate all helpful posts "The more you help the more you learn"
