Bandwidth of E1/T1 if it's used as WAN link
fayiz husain
Wha is the bandwidth of E1/T1 if it's used as WAN link?
3 Accepted Solutions
ronpatel
Level 8
Level 8
For T1 it would be :- Close to 1.480Mbps
For E1 it would be :- Close to  1.930Mbps
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Fayiz,
Channelized E1 - consists of 30B channels and 1D channel. Each channel has 64k Bw. So for E1 - you get 30*64 = 1920kbps
Channelised t1 - consists of 23B channels and a D channel - so you get 23*64 = 1472kbps.
Terry
Let me know what you are trying to implement. T1 or E1. Both have different way of implementation. What is your service provider giving you.
Ronak Patel
12 Replies 12
ronpatel
Level 8
Level 8
Ronak Patel
How can we calculate the bandwidth? Please explain in detail
Fayiz,
Terry
Thank you for your replies
What about the bandwidth of signaling and framing channels? Shouldn't we consider those if we are using T1/E1 as a WAN link?
Will these channels act together as a single channel? ie, can't we consider the channels seperately in case of WAN link?
Fayiz,
Even when its used for data - one channel, also called time slot is used for control/framing, it can be used to signal receiver end, start or end of frames, which can be used for detecting any lost bits etc. for CRC purposes.
So in short even though e1 is said to have 2048kbps and t1 1544 kbps you will not get full bandwidths and will have usable bandwidth approximately close to as mentioned in the above posts after leaving out d-channel and framing over head.
Terry
To add you can use full e1 bandwidth only if your telco is selling clear channel e1,which they normaly donot sell - mostly you will be getting channelised E1.
Terry
Can we use both CAS and CCS for E1/T1 if it's used as WAN ? Which one is recommended?
Ronak Patel
I have both E1 and T1. Can you describe about both, please?
Your provider will only provide you either E1 or T1 - T1 is used in US, Canada, Japan and E1 is pretty much used in rest of the world.
CAS, CCS or RBS are the signalling methods. You can think of these as protocols that run on top of T1/E1. RBS is the oldest one more closely replaced by CAS. CCS is the most recent one - PRI uses CCS. Without going much into signalling you should check with your provider for the options, what are they offering.
Terry
Its already explained above - physically both E1 and T1 are different - and offer different bandwidths. Both are different standards followed by different countries. You will not have choice in choosing T1 or E1, your provider will offer the circuit based on the standard your country is following either E1 or T1.
Terry
In the configuration of T1 as WAN link I've seen the command "channel-group" . This configuration is for CAS, right?
So my question is, can't we use CCS for T1 WAN link?
