CUCM clone
Marc El Achkar
I have a CUCM 8.6 running on VM which have a hard disk space of 500GB if i want to clone it with a smaller disk space so not everytime i do a backup it backsup 500GB, will i need new licenses for it to work after the clone?? or the current licenses will be working.
Mark
Chris Deren
You will need to rebuild the VM with different OVA as resizing disk space is not supported on CUCM. You can use DRS backup/restore.
HTH,
Chris
Ok and will i need to generate a new license or the old license will work?
No, at least if you don't change any parameter during the installatio process.
The license gets associated to a license MAC, which is a 12  digit HEX value created by hashing the following parameters that you  configure on the server:
Time zone
NTP server 1 (or "none")
NIC speed (or "auto")
Hostname
IP Address (or "dhcp")
IP Mask (or "dhcp")
Gateway Address (or "dhcp")
Primary DNS (or "dhcp")
SMTP server (or "none")
Certificate Information (Organization,  Unit, Location, State, Country)
The ways to obtain the license MAC are as follows:
Before installation, use the Answer  File Generator (http://www.cisco.com/web/cuc_afg/index.html).  When you generate the answer file, you also get the license MAC.
Please rate all useful posts
Favor calificar todos las respuestas útiles.
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
