01-12-2011 01:40 AM - edited 03-16-2019 02:49 AM
Gurus,
I have a user who has been using IP Com in the States (we have a CME), and recently Estonia on a WiFi connection, and had excellent results.
He is now in Malawi, and his computer gets Internet connectivity by means of a cellular dongle of some sort. He uses the Cisco VPN client to get connectivity back to the office.
He says that the dongle is reporting speeds of between 220 and 250 Mbps, but IP Com is unusable. What I can hear of him is choppy and broken, and what he can hear of me is even less.
However, seconds later he can fire up Skype and the conversation is nearly perfect.
So not having much experience thus far with IP Com, I was wondering if anyone knows what the bandwidth requirements are for it, or has any experience using it in a lower-bandwidth environment.
-Michael
01-12-2011 05:12 AM
This is a simple matter of CODEC selection. IP Communicator and Skype use two very different sets of CODECs.
Also worth noting, there is another option called iSAC; however, CIPC does not support this. This is even newer than iLBC to Cisco and, while promising, is only possible with CSF or 8900/9900 series phones at present.
For now, your best bet will be to get iLBC working if you want to use the Cisco client. Also, changing your VPN client to UDP instead of TCP would help. TCP-based IPsec tunnels spend time/bandwidth retransmitting packets that won't be useful.
