BAT File SNR Possible?
cguglielmo1
I have about 140 users we are adding into CUCM. I will need to create 140 SNR profiles for these users. Is it possible to do this with a bat file? If not any suggestions.
Thanks!
6 Replies 6
Jim duPuis
In version 11.5 I just ran some test imports fine from Bulk Administration, Import/Export, Import. Made the imports based on exporting existing config in the same way, Bulk Administrations, Import/Export, Export then check Remote Destination and Remote Destination Profile. If you have one of each existing, the results from BAT should make sense.
Great!
I just pulled 2 reports with all of my current users. I have remotedestination and RDP. Will I need to update both files and then upload both files?
Thanks again!
Yes, you'll have to update both files. I think you'll have to process the profiles first, then you can add the destinations, since the destinations point back to the profiles.
Thank you for your help! I will test it out today and update the forum.
Worked Perfectly!
Thanks for your help!
Please let me know which fields you needed to update in bulk document?
