02-02-2017 09:50 AM - edited 03-17-2019 09:23 AM
I have a new BE6000S box, and I'm pretty new to cisco voip product.
Right now, I have setup the internal environment and it works fine. However, I want to configure a trunk to make some outbound test calls and I really have no idea about how to configure the voice gateway to connect to the ITSP, anyone have successfully configured this product can give me some tip?
Here is the configuration that i run from the be6000 router/voicegateway.
BE6000S#sh run
Building configuration...
Current configuration : 10858 bytes
! Last configuration change at 13:39:58 PST Wed Feb 1 2017 by hanatech
! NVRAM config last updated at 13:00:59 PST Wed Feb 1 2017 by hanatech
version 15.5
service compress-config
service sequence-numbers
hostname BE6000S
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
enable password ************
aaa new-model
aaa authentication login default local
aaa session-id common
ethernet lmi ce
clock timezone PST -8 0
clock summer-time PDT recurring
network-clock-participate wic 0
ip dhcp excluded-address 172.27.199.1 172.27.199.31
ip dhcp pool BE6000S-Preconfigured-S1
import all
network 172.27.199.0 255.255.255.192
default-router 172.27.199.1
option 150 ip 172.27.199.11
dns-server 172.27.199.1
domain-name ciscolocal.com
lease 0 2
ip domain name ciscolocal.com
ip host ucn1.ciscolocal.com 172.27.199.12
ip host plm.ciscolocal.com 172.27.199.11
ip host pcp.ciscolocal.com 172.27.199.10
ip host s1-cimc1.ciscolocal.com 172.27.199.2
ip host ns.ciscolocal.com 172.27.199.1
ip host s1-esxi1.ciscolocal.com 172.27.199.4
ip host ntp.ciscolocal.com 172.27.199.1
ip host ucm-pub.ciscolocal.com 172.27.199.11 2001::172:27:199:11
ip host imp1.ciscolocal.com 172.27.199.13
ip host s1-dgw.ciscolocal.com 172.27.199.1
ip host s1-ns.ciscolocal.com 172.27.199.1
ip host s1-vgw.ciscolocal.com 172.27.199.1
ip host s1-ntp.ciscolocal.com 172.27.199.1
ip host _cisco-uds._tcp.ciscolocal.com srv 0 1 8443 ucm-pub.ciscolocal.com
ip host _cuplogin._tcp.ciscolocal.com srv 0 1 8443 imp1.ciscolocal.com
ip multicast-routing
ip cef
no ipv6 cef
isdn switch-type primary-net5
trunk group ALL_PSTN
crypto pki trustpoint TP-self-signed-2314118582
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2314118582
revocation-check none
rsakeypair TP-self-signed-2314118582
crypto pki certificate chain TP-self-signed-2314118582
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32333134 31313835 3832301E 170D3137 30313133 31353436
35305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 33313431
31383538 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100B612 E922C5C9 DE006D62 A9AC7722 181649FC 3552A5A1 31011847 8DF7173B
70AC839F 50458C88 0A1AF43E 29DDBA2A AFAEA88C 46FE6E03 63344C0D 48948982
837AC0F6 0B21F37D E3792FA7 96BE44AA 86875FAD 89D3F2F6 DAE525C5 9490DF81
1ED585ED 22ECC19E 4B353BC7 100148EA 16D87AFC 4C6239FA F10914F9 E4F5E1A2
83E30203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 1440C6EE F4354019 592FD4C1 AA9065A6 FAC1572C A5301D06
03551D0E 04160414 40C6EEF4 35401959 2FD4C1AA 9065A6FA C1572CA5 300D0609
2A864886 F70D0101 05050003 818100A4 0D38E9FD B6D58399 243B60E6 4FE45C3B
A272F64B 97184034 560706BB F36A5004 783B53FB D9A06C78 4656D40F EEEAC5BC
A3451251 42F70EBD DBFF9B71 660E1C5F 4ABB8C00 FF82B85C 19D5D9DD 1CDC6C10
D8274864 D782700D F0A56CE5 17CC9A39 79AE1FF8 AF171A59 1C92D9BF F6AB088B
23F958B9 B0ED7290 5E86C25D 8029FA
quit
voice-card 0
voice service voip
ip address trusted list
ipv4 172.27.199.11
ipv4 172.27.199.14
ipv4 172.27.199.15
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
no fax-relay sg3-to-g3
modem passthrough nse codec g711ulaw
sip
bind control source-interface BVI1
bind media source-interface BVI1
asymmetric payload full
no update-callerid
voice class uri ucm sip
host ^172.27.199.1[145]$
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g711alaw
codec preference 4 ilbc
voice translation-rule 1
voice translation-rule 2
rule 1 /^.*\(...\)$/ /1\1/
voice translation-rule 3
rule 1 /^.\(...\)$/ /5551234\1/ type any national plan any isdn
voice translation-rule 4
rule 1 /^\+1\(...\)/ /\1/ type any national plan any isdn
rule 2 /^\+1\(.*\)/ /1\1/ type any national plan any isdn
rule 3 /^\+\(.*\)/ /011\1/ type any international plan any isdn
voice translation-profile PSTN-to-UCM
translate calling 1
translate called 2
voice translation-profile UCM-to-PSTN
translate calling 3
translate called 4
fax interface-type fax-mail
license udi pid CISCO2921/K9 sn FJC2102A1G5
hw-module pvdm 0/0
hw-module sm 1
archive
log config
logging enable
logging size 600
hidekeys
redundancy
controller E1 0/0/0
pri-group timeslots 1-31
description Primary Rate Connection to PSTN
bridge irb
interface Embedded-Service-Engine0/0
no ip address
ip broadcast-address 0.0.0.0
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address dhcp
ip pim sparse-dense-mode
ip igmp version 3
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
bridge-group 1
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn sending-complete
isdn outgoing display-ie
trunk-group ALL_PSTN
no cdp enable
interface ucse1/0
description Internal interface connected to UCSE Port 0
ip unnumbered BVI1
service-module heartbeat-reset disable
imc ip address 172.27.199.2 255.255.255.192 default-gateway 172.27.199.1
imc access-port shared-lom console
bridge-group 1
interface ucse1/1
description Internal switch interface connected to UCSE Port 1
no ip address
interface Vlan1
no ip address
interface BVI1
description Bridge interface providing access to router and UCSE module.
ip address 172.27.199.5 255.255.255.192 secondary
ip address 172.27.199.1 255.255.255.192
ip broadcast-address 172.27.199.0
ip igmp version 3
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
snmp-server community public RO
access-list 23 permit 10.0.0.0 0.255.255.255
access-list 23 permit 172.16.0.0 0.15.255.255
access-list 23 permit 192.168.0.0 0.0.255.255
control-plane
bridge 1 protocol ieee
bridge 1 route ip
voice-port 0/0/0:15
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 pots
trunkgroup ALL_PSTN
description Default inbound dial-peer for calls from PSTN
translation-profile incoming PSTN-to-UCM
incoming called-number .
direct-inward-dial
dial-peer voice 50 voip
description Inbound voip dial-peer for calls from UCM
session protocol sipv2
incoming uri from ucm
voice-class codec 1
dtmf-relay sip-kpml rtp-nte
no vad
dial-peer voice 100 pots
trunkgroup ALL_PSTN
description E.164 calls from UCM to PSTN
translation-profile outgoing UCM-to-PSTN
destination-pattern +.+
forward-digits all
no sip-register
dial-peer voice 200 voip
description Calls from PSTN to UCM
destination-pattern 1...
session target ipv4:172.27.199.11
voice-class codec 1
no vad
sip-ua
timers trying 100
gatekeeper
shutdown
banner exec ^C
Cisco Business Edition 6000S
You must create a new user name and password using Cisco CP or the following
CLI command before continuing to use this system:
username <newusername> privilege 15 secret <newpassword>
WARNING: This system includes a Cisco UCS server module which MUST be shut
down (power button is orange) before removing power. Failure to shut down
gracefully may result in data loss or corruption.
For further information, refer to the BE6000S installation guide:
www.cisco.com/go/be6ksig
^C
banner login ^C
This appliance has been preconfigured for your convenience. You may manage
this system locally via console, or by connecting to 172.27.199.1 through
interface GigabitEthernet 0/1 using Telnet, SSH or Cisco Configuration
Professional (Cisco CP) via HTTP. DHCP is enabled for client configuration.
For initial access, log in with user name "admin" and password "password".
These credentials may be used for the first log in ONLY. If you log out
without creating a new user name, you may not be able to log in again.
^C
line con 0
exec-timeout 0 0
privilege level 15
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
speed 9600
flowcontrol software
line vty 0 4
exec-timeout 0 0
privilege level 15
transport input telnet ssh
line vty 5 15
exec-timeout 0 0
privilege level 15
line vty 16 1114
exec-timeout 0 0
transport input none
scheduler allocate 20000 1000
ntp master 3
ntp update-calendar
ntp server 0.ciscosb.pool.ntp.org
ntp server 3.ciscosb.pool.ntp.org
ntp server 1.ciscosb.pool.ntp.org
ntp server 2.ciscosb.pool.ntp.org
end
