Resolved! Busy extension not going to voicemail
Busy extension are not going to voicemail. What is the best way to troubleshoot or resolve this.
Dear All, I have a device profile for extension mobility. After logging on to a desk phone user is unable to make a particular international call from his line. So, I am trying to do DNA using his line as a directory number in DNA findings, but DNA s...
I have a CUCM 10.5 cluster with 79XX series phones - from time to time the personal and corporate directories just disappear from the handset. A phone reboot brings them back but I'd rather get to the root cause of the issue rather than just fix the...
Hi All, I have an H323 gateway that has multiple numbers delivered to it. We are using overlap sending and the gateway is in Germany so we have variable length dial plans to deal with. I know this isnt a good design (I unfortuantely had no control...
Hello Everybody I have just received a Cisco 2951 that someone has formatted its flash. There is not CME files and directories on flash:/. I tried to load firmware for my 7906 phones. I tried to configure but Phones do not register. So, can anybody h...
Hello, I have following environment: Cisco Jabber 11.8.1 iOS, MRACisco Jabber 11.8 Windows 7Mi4, 4.4.4 MRACUCM 11.5.1.12900-21 Unrestricted In CUCM 11.5 Cisco mobile and remote access clients and endpoints can now search a corporate directory server ...
Dear Gents, Often phone is getting hanged , we are using CUCM 11.x all the phone firmware are up to date. Wondering what could be the issue?
Hi, Cisco IP Phone 7800 and 8800 Series devices) as well as future IP phones no longer report MOS The advantages of using concealed seconds (CS) and severely concealed seconds (SCS) metrics, a process that is more efficient and reliable on a typical ...
we have h323 gateway with fxo lines . there is a problem now . while transferring calls and being on pstn calls phones are becoming unregistered and the call disconnect . this issue is not in place when making internal calls . please suggest .when I ...
Customer currently has some 7900 series phones using the certificate-based remote VPN feature through their ASA firewall. They have some new Palo Alto firewalls and would like to know if they can get these phones to register from the users' home netw...
We are in the midst of switching from one ISP to another. I received the router and need to put it in front of the UC520. My only problem is that inbound calls aren't working. I ran the logs and found the following error. Is there an easy way to ...
HI, please i have CME version 9.1 and i need to register 7861 ? how to proceed please, thanks
Does a gateway have to be H323 in order to get caller ID on FXO ports? I have a 2911 gateway, IOS version 15.4(3)M3. The gateway is MGCP. It works sporadically. I was wondering if there is a timer that can be adjusted.
hii have juste installed and configured the cisco attendant console advanced 11 with cucm 11.5all function good i have generated all reports available on reporting interface on the server but i noticed that there is no information about caller id of ...
Hello all, I have a new SIP Trunk I am trying to get to register with the ITSP. I have set the credentials and authentication username and password. When I try to place a call and check the debug I am just sending a Invite. I never see a register bei...
Subject | Author | Posted |
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM | ||
05-16-2025 12:03 AM |
User | Count |
6 | |
4 | |
3 | |
2 | |
1 |
