Best way to restart the SIP-UA Registration process without Gateway reload
Keith Fulcher
What is the best way to kick start, or restart the SIP-UA registration process on a cube ... other than restarting the gateway or deleting the registrar info and re-adding it.
Note: This SIP Provider is not on a dedicated interface so shut/no shut is not applicable here.
Something like "Restart SIP-UA"?
voice service voip
shut
no shut
Try this command and see if it helps
call service stop
It will shut down VoIP call service [SIP] on a gateway, use this in voice service SIP.
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
AlejoSan
Hi, i want to add an additional help
rt#conf t
rt(config)#voice service voip
rt(config-voi-serv)#sip
rt(config-serv-sip)#call service stop
rt(config-serv-sip)#no call service stop
rt(config-serv-sip)#end
now check that the calls enter the gw.. sh sip-ua calls brief or run a debug ccsip message
bye
