08-03-2011 06:02 AM - edited 03-16-2019 06:16 AM
Hi Guys,
My Customer have the solution with CallManager 5.1.3 using the MGCP and would like blocked called ID for outgoing calls. My question is: Is It possible block in the CallManager 5.1.3 or only carrier can be blocked the Called ID outgoing? The additional information, the PSTN using the Primary QSig
Wilson
08-03-2011 06:04 AM
in nrmal cases you can block or mask the outgoing calling ID
yoiu can do it on the route pattren level, route list level or GW level
08-03-2011 06:10 AM
Hi Marwanshawi,
Thank You for answer. My Customer would like that in called number appear the message "know number". Could You pass more ddetails who to do this configuration in Route Pattern or Route List. Are there any documentation about this?
Thanks again,
Wilson
08-03-2011 06:19 AM
On the Route pattern you have Calling Line ID - Allowed, Default, Restricted- You can do it here
08-08-2011 07:31 AM
Hi Guys,
I am sorry by delay. I changed the parameter in the Gateway, in the Route Pattern, but, didn´t work. The called number still to see the number of calling. Another have idea about this?
Wilson
08-08-2011 04:01 PM
Wilson,
On the MGCP gateway --> endpoint
Look at the section for outbound calls
Change the Calling Party Presentation (Drop down) to "RESTRICTED"
This is last element for a call leaving CUCM/MGCP passes through.
Hope this helps
Alex
08-09-2011 04:50 AM
Hi Alex,
I did had already this change configuration, but, didn´t worked.
Wilson
08-09-2011 04:54 AM
What number is being sent- could it be your Telco sending it ?
08-09-2011 05:15 AM
what number is being sent- is it DDI/External Mask .
08-09-2011 05:17 AM
Hi iptuser55,
The number that is sending is principal number, for example, the range the number is 5741-2000 until 5741-2999, It send the 5741-2000. Yes, I believe that the Telco is sending it.
Wilson
08-09-2011 05:21 AM
I think you need to tell the telco to restrict in that case
