Block Route Pattern on CCM 4.2
alemunmo81
Hello
I have configured a sip trunk on CCM 4.2, also i have created a route pattern selecting the sip trunk. So, when i am analyzing the digits dialed, the tool show me that the route pattern is blocked. How can i do on CCM 4.2 for finding more details of this block route pattern and also the reasons???
I would appreciate any help.
Alexis
Jaime Valencia
You can look at the route plan report to see if there is another route pattern or translation patterns that is blocking the call, or you can look at CUCM detailed traces
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
asandborgh
Level 4
Level 4
Alexis,
I've seen this before on 4.2 but don't know why it happens.  As you describe DNA shows it blocked but it looks normal on the configuration screens.  Try deleting the route pattern and inputting it in again - that is what has worked for me in the past.
HTH,
Art
