Blocking External Caller
scorpio.besal
Hi All,
 I have got an request to block an external caller because the entire department keeps getting spam phones call by this number and would like it blocked.
Need your advice.
2 Accepted Solutions
Jaime Valencia
There's plenty of documentation on this topic for reference
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/64020-number-voice-translation-profiles.html#con11
This is a local config, if you receive those calls on all 6 gateways, then yes, you need to configure it on all of them.
java
if this helps, please rate
Make sure the call is hitting this dial-peer where the block profile is applied. The incoming call should have exactly same digits to match - make sure to include/exclude any leading digits.
You can check this by running the: debug isdn q931.
If you still have issues, run the below debugs while making the test call. Post the output of these here.
debug voip ccapi inout and debug voip dialpeer inout
-Terry
Please rate all helpful posts
9 Replies 9
Jaime Valencia
java
Thanks for the link.
Could you advice if I have to apply the config to all the VG's ( I have 8 gateways in 4 different offices)
Thanks for your help.
Already did
java
Thanks matey
One last question, would there be downtime if I  apply this config.
No, you just configure and apply to get it to work.
java
I just tried applying the following config on my local VG where i have the VOIP phone, but its not working. I tried to block my mobile 093232323232 to test
-Terry
