Blocking numbers on a Cube
martynch1
I'm looking to block a couple of mobiles numbers when they hit our Cube as we are getting nuisance calls, I think it’s done by creating translation rules, I'm just unsure who to achieve this.
We already have translation rule for an outbound rule which is
voice translation-rule 1
rule 1 /^\([267-9]......\)$/ /01623\1/
voice translation-profile OutboundCalledPartyforShortDIAL
translate called 1
And this is applied to dial-peer 10
dial-peer voice 10 voip
description *** CUCM to CUBE (Inbound) ***
translation-profile incoming OutboundCalledPartyforShortDIAL
session protocol sipv2
session transport tcp
destination dpg 90
incoming uri via CUCM
voice-class sip bind control source-interface GigabitEthernet0/0/1
voice-class sip bind media source-interface GigabitEthernet0/0/1
dtmf-relay rtp-nte sip-kpml sip-notify
codec g711alaw
no vad
So I think I need to create another rule as follows:
voice translation-rule 2
rule 1 reject /0797XXXXXX1/
rule 1 reject /0797XXXXXX2/
voice translation-profile CALLBLOCK
translate calling 2
But this is where I come unstuck if I try and add this to dial-peer 10 it just replaces the rule, do I need to create another Dial peer like below, if so how do the calls hit this dial-peer, are they like ACL's and step down the dial-peers?
dial-peer voice 11 voip
translation-profile incoming CALLBLOCK
destination dpg 90
codec g711alaw
no vad
Thanks all
Martyn
tyroneclark871
Hi, there is a simpler way...
rule 1 reject /0797XXXXXX[12]/
voice translation-profile BLOCK
translate calling 2
dialpeer voice 11 voip
incoming called-number .
call-block translation-profile incoming BLOCK
call-block disconnect-cause incoming call-reject
Hope this helps!
Thanks for your response, so my thinking was along the correct lines then?
Do dial-peers work in the same was as an acl, would I need to put the blocked dial-peer above the the original, so if it matches it blocks, if not then it moves on?
I would suggest placing the more specific matches higher up, but to answer your question; dial-peers are similar but the hierarchy for dial-peers doesnt really affect the funtionality. See dial-peer document below for more specific information pertaining to dial-peers and call legs.
https://www.cisco.com/c/en_intl/support/docs/voice/call-routing-dial-plans/12164-dialpeer-call-leg.html
Sorry for the delay, I will give the document a read.
