Resolved! CME Second line Call forwarding
I have recently deployed CME, on line 1 i can see Call Forward softkey, but on line 2 it does not appear. Its SIP phone which i am using Cisco 4431 VG
I want to sync my contact between Iphone 7 and Cisco IP 8851 There is a limit at 1 000 contacts. How can I go further ? Thanks for your help
I recently upgraded CUCM from version 11.0 to 11.5; afterwards, all of our phones upgraded just fine except one. On the display it shows that it's trying to download a SIP load instead of SCCP. I've reset the phone several times using both 123456789*...
Hi all. I have an AA that have options, one of them is to give the caller the opportunity to dial an extension number of they desire. I want to route (if is possible) an specific number when user dialed. imagen you are looking for Mr. Pit at ext 222...
Hello, After an firmware downgrade to version 15.0, the system was crashed. The switch comes up whit attached error message via terminal. How can I recover the firmware on this state? Thanks Michael
I have a unity connection cluster running on 10.5.2. Over the weekend i saw some alerts regarding cluster manager state and we kicked off the week with users complaining about MWI. When we checked the status of the cluster it showed both the servers ...
Hello - I have a senario where I want to put CME at 1 location and Unity Connection at a second location with an auto attendant. Is there a way to redirect calls to a hunt list on CME in the event CME cannot contact Unity Connection?
We are setting up a new small branch office that will be running of a centralized CUCM cluster. When going to purchase the router we were going to use a 4321 and also get a VG310 as there are a number of analog lines required at this site. It was t...
Here is my situtation - Brand new 9.1.x cluster. LDAP was not ready, so local users we configured so that I could import the phones. In previous versions of CUCM, once LDAP intergation was enabled, the existing local users would be replaced by the ...
We have simple cisco jtapi application, the primary use of this application is to capture all event from CUCM (Call Answer, Call initiate, call hold, call resume, call transfer, call conf). We are able to achieve call Answer and Call Initiate by usin...
Rumor is Cisco is no longer going to do any further feature development for Jabber besides some features coming up in the next release. They want everyone to move to Spark. They have given Jabber 3-4 years more before they announce end of life. A...
I have a client that is looking to allow internal users to call Locally and Toll-Free. Unfortunately, the CORs available do no allow that without opening full long distance calling. Internal—Privileges to call numbers that are internal to the o...
I have been unsuccessful with adding a custom image to the 8841 VOIP phone. I cannot seem to find/create the list.xml file. I have sshed into the CUCM but first insured the TFTP services were started. CUCM version 10.5. I also created a new Common ph...
I have just come into a new organization and things are a bit of a mess here. I have been doing some discovery on one of their CUCM clusters and many of the gateways are setup as MGCP. I need to access the gateways but cannot figure out what the ac...
So, there is a user at ext 1234 that is no longer with the company. Ops is requesting that ext (1234) have calls forwarded (which has been accomplished), and have access to that ext VM. Also would like for all incoming calls to ext 1234 be transfer...
Subject | Author | Posted |
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM | ||
01-16-2023 05:26 PM | ||
01-16-2023 10:22 AM |
User | Count |
7 | |
7 | |
4 | |
4 | |
1 |
