Bogusip and Old Hostname in Unified CM Services Report Section
m.gravel
All.
I just recently performed an upgrade test in a lab.  In this scenario I needed to change the IP addresses and host names of the Communications Manager.  I performed a back and restore and then upgraded that restore in a virtual machine.  I only restored the first node and then proceeded to change the ip addresses in the servers section of the GUI admin (servers are defined by IP) and then changed the IP of the first node in the CLI along with the hostname change after that.  When that was done I simply installed the four other subscribers in parallel with the new hostnames and IP addressess.
Everything in Cisco Unified Reporting for the report Unified CM Database status shows green and all looks good.  The only thing that looks odd is a section of the report called Unified CM Services which still has some entries for the old host name and some lines that say bogusip in them.
I'm wondering why I still have the references to the old publisher hostname and why I have the entries for bogusip.  They only appear to be on the publisher file.  All the subscribers look clean.  I am wondering if there is a way to clean this up and or if its something i need to be concerned about.
I have changed the hostnames and IP's for this post.  Here is a brief description of them:
Old IP               Old Hostname          New IP     New Hostname
10.26.1.1                                        10.1.1.2     siteacucms1
10.29.202.1                                    10.2.1.2     sitebcucms4
10.30.1.1                                        10.2.1.1     sitebcucms2
10.28.1.1                                        10.1.1.3     siteacucms3
10.31.1.1     oldsiteapub                    10.1.1.1    siteacucmp1
Server    services File
10.1.1.1
### IDS BEGIN - DO NOT REMOVE
siteacucmp1_ccm8_6_2_21900_5    1500/tcp    # IDS on siteaCUCMP1
siteacucms1_ccm8_6_2_21900_5    1500/tcp    # IDS on siteaCUCMS1
siteacucms3_ccm8_6_2_21900_5    1500/tcp    # IDS on siteaCUCMS3
sitebcucms2_ccm8_6_2_21900_5    1500/tcp    # IDS on sitebCUCMS2
sitebcucms4_ccm8_6_2_21900_5    1500/tcp    # IDS on sitebCUCMS4
bogusip_10_1_1_2_ccm8_6_2_21900_5    1500/tcp    # IDS on BogusIP_10_1_1_2
bogusip_10_1_1_3_ccm8_6_2_21900_5    1500/tcp    # IDS on BogusIP_10_1_1_3
bogusip_10_2_1_1_ccm8_6_2_21900_5    1500/tcp    # IDS on BogusIP_10_2_1_1
bogusip_10_2_1_2_ccm8_6_2_21900_5    1500/tcp    # IDS on BogusIP_10_2_1_2
oldsiteapub_ccm8_6_2_21900_5    1500/tcp    # IDS on OLDSITEAPUB
bogusip_10_26_1_1_ccm8_6_2_21900_5    1500/tcp    # IDS on BogusIP_10_26_1_1
bogusip_10_29_202_1_ccm8_6_2_21900_5    1500/tcp    # IDS on BogusIP_10_29_202_1
bogusip_10_30_1_1_ccm8_6_2_21900_5    1500/tcp    # IDS on BogusIP_10_30_1_1
bogusip_10_28_1_1_ccm8_6_2_21900_5    1500/tcp    # IDS on BogusIP_10_28_1_1
oldsiteapub_ccm8_6_2_21900_5        1500/tcp        # CCM IDS Server
### IDS END - DO NOT REMOVE
10.1.1.2
siteacucms1_ccm8_6_2_21900_5        1500/tcp        # CCM IDS Server
10.1.1.3
siteacucms3_ccm8_6_2_21900_5        1500/tcp        # CCM IDS Server
10.2.1.1
sitebcucms2_ccm8_6_2_21900_5        1500/tcp        # CCM IDS Server
10.2.1.2
sitebcucms4_ccm8_6_2_21900_5        1500/tcp        # CCM IDS Server
Marc
Priyadarshini B.T
Since the database replication status and everything else shows a good sign, except for the above errors you have mentioned popping up.
BogusIP is due to since there are many repeatedly Subs IP address entries exists in the /etc/services file, which in general should not cause any harm.
But if you dont want it to appear, then we need to get the remote access account, and then ssh to the linux shell, and remove this entries and all the duplicate
entries can  be removed.
You might have to open a TAC case.
Thanks for the information Priya.  I may just open one to get it cleaned up.
