BRI CONFIGURATION
micordoba
I have an UC560 with a PRI Trunk and 2 BRI Ports for call to mobile phones. The PRI Trunk works ok but I have problems with the Bri ports, I receive the calls in the bri ports but it finish in a second. When I do a debug isdn q931 I see that I not receive the called number and for that I can not send the call to an extension, autoattendant or group. The Bri provider said me that they can't send me the called-number.
Can I send all incoming-calls in this group of Bri ports to autoattendant? I do it with the FXO ports but I can't with de Bri ports. I try to do it in command line and with CCA and in CCA I can't find the option if I don´t have the called number.
Thanks in advance.
Arun Thomas
  Do you receive 'calling number' ?
Try a voice translation rule on  voice port - incoming direction
voice translation-rule 1
rule 1 /.*/ /AA number/
Since you're not even receiving a single digit, not sure this will work.
Please post the BRI interface configs here, Also try to configure the interface for overlap receiving
http://www.cisco.com/en/US/docs/ios/12_1/12_1xi/feature/guide/dt_brint.html
As you are not receiving any digits you can use PLAR to route calls  to your selected device on
incoming port seizure
voice-port 0/0/1
connection PLAR 1234
Here 1234 could be an ip phone or auto attendant pilot etc
Alex
Regards, Alex. Please rate useful posts.
100 % correct ! since you're not receiving any digits as a 'called number' BRI is acting like a typical FXO port and 'connection plar' should work.
If that doesnt solve your problem, please post the dial peer and interface configs for BRI
Make sure that you have 'direct-inward-dial' configured on the incoming pots dial-peer
