I configured the "max-conn" parameter on my H323 voice gateway (see "dial-peer" here below).
When the maximum number of calls is reached, the calling party receives the "out of order" tone.
Is it possile to configure something so he would receive the "busy" tone in that case in place of that "out of order" tone?
dial-peer voice 26 voip
description 9611 To CCM Publisher
preference 1
max-conn 20
answer-address .
destination-pattern 9611
progress_ind setup enable 1
translate-outgoing calling 1
modem passthrough nse codec g711alaw
voice-class codec 10
voice-class h323 1
session target ipv4:172.16.251.5
dtmf-relay h245-alphanumeric
fax rate disable
no vad
Thanks in advance if you can help me.
