- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-02-2009 08:31 AM - edited 03-15-2019 08:20 PM
Hi all,
I have a system UC520-32U-4BRI-K9 (PC8358) with Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 12.4(11)XW6, RELEASE SOFTWARE (fc2)
I have some ephone-dn configured as dual-line.
How could I get a busy tone when one call is active in that directory number? Is it possible without loss options like call waiting option, call transfer and so on?
Solved! Go to Solution.
- Labels:
Other IP Telephony
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-02-2009 08:55 AM
Hi Raul,
Yes, the features of Dual-Line will still persist, like Transfer.
Cheers!
Rob
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-02-2009 08:39 AM
Hi Raul,
Because the DN's are set up as dual-line you need to add the following (huntstop channel command). Have a look;
The following example creates an ephone-dn with the number 103 in dual-line mode. The no huntstop command allows calls to continue to hunt to other ephone-dns if this one is busy or does not answer. The huntstop channel command disables call hunting to the second channel of this ephone-dn if the first channel is busy or does not answer.
Router(config)# ephone-dn 10 dual-line
Router(config-ephone-dn)# number 103
Router(config-ephone-dn)# no huntstop
Router(config-ephone-dn)# huntstop channel
Router(config-ephone-dn)# exit
Hope this helps!
Rob
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-02-2009 08:50 AM
Rob,
Thank you for your quick response,
I'll try it with my customer.
Only for being sure, with this command in the ephone-dn, this directory number is able to apply a call tranfer?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-02-2009 08:55 AM
Hi Raul,
Cheers!
Rob
