C2911 Personal Speed Dials
kevin0neill
I can only add Personl Speed Dials from the Command line. I want to be able to add Personal Speed Dials from the phone (7942G)
Using cisco IP communicator. Directories Button gives Personal Speed Dial as option 6 and this displays the available Personal Speed Dials correctly.
To add from the phone, I use the Services Button followed by My Phone Apps, then selecting Personal Speed Dial displays error message "Host Not Found". Can anybody assist please?
kevin0neill
I have the LocalSpeeddials working by adding speeddial.xml. The Personal Speeddials work fine by adding to the ephone via the command line, but if you try to add from the 7942 services button, you get "host not found". Is there another xml file that need to be added?
I'm now using a CIPC and wireshark. The reason I get "host not found" seems to be caused by the url missing the last character of the phone mac address:
My Phone Apps; Speed Dial Buttons gives http://x.x.x.x/CMEserverForPhone/spd_cnf_menu0011955a9e54 which is correct and works fine, but My Phone Apps; Personal Speed Dial gives http://x.x.x.x/CMEserverForPhone/fsd_cnf_menu0011955a9e5 which is missing the last character "4"
Is there a bug here that I should know about?
