C2921 CME MLPP with PLAR connection on FXS port
abrashic
I have a strange setup running a PLAR line off of one of my FXS lines in my 2921 router.
With all FXS portws setup for MLPP, I can pickup the handset acess the MLPP code and dial with no issue., ie dial extension 1234 with MLPP code 80 - reulst is dialing 801234.
When I set up the same port to use PLAR with the extension 801234, the signal received is busy-out.  Anyone know a work around?  The PLAR to 1234 works fine but I don't have the ability to bump the call in progress due to the incoming hotline.
Alex
Tagir Temirgaliyev
sorry, can not undestand without running config
Config as requested.  I did bold the line in question.
Current configuration : 7397 bytes
! Last configuration change at 22:26:21 UTC Mon Feb 11 2013 by
version 15.2
hostname Trunk3_Rtr
boot-start-marker
boot-end-marker
card type e1 0 3
logging buffered 51200 warnings
enable secret 4 GRkmoIEZHE5MJGS32fAHPEURWnt6MpoR9ORNpmJoAf6
no aaa new-model
network-clock-participate wic 3
ip cef
ip dhcp excluded-address 10.3.1.0 10.3.1.100
ip dhcp excluded-address 10.3.2.0 10.3.2.100
ip dhcp pool Data
network 10.3.1.0 255.255.255.0
default-router 10.3.1.1
dns-server 10.3.1.1
ip dhcp pool VoIP
network 10.3.2.0 255.255.255.0
default-router 10.3.2.1
dns-server 10.3.2.1
no ipv6 cef
isdn switch-type primary-net5
voice-card 0
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice mlpp
access-digit 8
bpa flash:bpa.au
bnea flash:bnea.au
upa flash:upa.au
service-domain drsn identifier 000001
license udi pid CISCO2921/K9 sn FTX1703AH86
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 1
redundancy
controller E1 0/3/0
pri-group timeslots 1-16
controller E1 0/3/1
shutdown
ip ssh version 2
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.100.1 255.255.255.0
duplex autospeed auto
interface GigabitEthernet0/1
ip address 10.50.3.1 255.255.0.0
media-type sfp
interface GigabitEthernet0/2
ip address 192.168.200.1 255.255.255.0
duplex auto
speed auto
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface GigabitEthernet1/0
description Gig Interface to Backplane
ip address 8.8.8.9 255.255.255.252
interface GigabitEthernet1/0.1
description Data Vlan Interface for 24 Port Switch
encapsulation dot1Q 101
ip address 10.3.1.1 255.255.255.0
interface GigabitEthernet1/0.2
description Voice Vlan Interface for 24 Port Switch
encapsulation dot1Q 102
ip address 10.3.2.1 255.255.255.0
interface GigabitEthernet1/0.3
description Wireless Vlan Interface for 24 Port Switch
encapsulation dot1Q 20
ip address 10.20.3.1 255.255.0.0
interface GigabitEthernet1/1
description Internal switch interface connected to Service Module
no ip address
interface Vlan1
no ip address
router ospf 1
network 10.0.0.0 0.255.255.255 area 0
ip default-gateway 10.2.1.1
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
control-plane
voice-port 0/0/0
mlpp service-domain drsn identifier 000001 max-precedence 0
description Trunk FXS Line 1
station-id name Trunk3 Analog1
caller-id enable
voice-port 0/0/1
connection plar 8020301 ************  With 20301, PLAR works.  The MLPP prefix of 8X causes fast busy.
description Trunk FXS Line 2
station-id name Trunk3 Analog2
caller-id enable
voice-port 0/0/2
description Trunk FXS Line 3
station-id name Trunk3 Analog3
caller-id enable
voice-port 0/0/3
description Trunk FXS Line 4
station-id name Trunk3 Analog4
caller-id enable
voice-port 0/3/0:15
voice-port 0/1/0
description Trunk FXO Line 1
voice-port 0/1/1
description Trunk FXO Line 2
voice-port 0/1/2
description Trunk FXO Line 3
voice-port 0/1/3
description Trunk FXO Line 4
voice-port 0/2/0
description Trunk BRI Line 1
voice-port 0/2/1
description Trunk BRI Line 2
mgcp profile default
dial-peer voice 1 pots
destination-pattern 20301
port 0/0/0
dial-peer voice 2 pots
destination-pattern 20302
port 0/0/1
dial-peer voice 3 pots
destination-pattern 20303
port 0/0/2
dial-peer voice 4 pots
destination-pattern 20304
port 0/0/3
dial-peer voice 11 voip
destination-pattern 201..
session target ipv4:10.1.1.1
dial-peer voice 12 voip
destination-pattern 202..
session target ipv4:10.2.1.1
dtmf-relay h245-alphanumeric
dial-peer voice 41 pots
destination-pattern 9123T
port 0/3/0:15
gatekeeper
shutdown
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
flowcontrol software
line vty 0 4
access-class 23 in
exec-timeout 480 0
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
