10-07-2008 01:13 AM - edited 03-15-2019 01:46 PM
In call Manager express Earlier(3.2/3.3/4.1,4.2) Call blocking is supported on IP phones only and not on analog foreign exchange station (FXS) phones.
Now we upgraded the Call Manager express 4.3/7.0 and after upgrade we are not able to make a call from Analog phone connected to FXS port.
How can we solve this issue.
10-07-2008 05:46 AM
Let me add non working configuration for FXS here
FXS configuration
voice-port 0/1/0
cptone GB
voice-port 0/1/1
dial-peer voice 4343 pots
destination-pattern 343
port 0/1/0
dial-peer voice 4334 pots
destination-pattern 334
port 0/1/1
telephony-service
load 7914 S00104000100
load 7911 SCCP11.7-2-1-0S.loads
load 7912 CP7912080001SCCP051117A
load 7920 cmterm_7920.4.0-01-08
load 7960-7940 P00307020200
load 7970 TERM70.6-0-2SR1-0-5s
max-ephones 240
max-dn 150
ip source-address 10.1.132.1 port 2000
time-zone 21
time-format 24
date-format dd-mm-yy
voicemail 600
mwi relay
max-conferences 8 gain -6
call-forward pattern .T
moh moh.wav
web admin system name admin secret 5 $1$Vo55$qjh9V5FyNOhK.t4kk31tK/
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
login timeout 5
after-hours day Sun 00:00 23:59
after-hours day Mon 00:00 23:59
after-hours day Tue 00:00 23:59
after-hours day Wed 00:00 23:59
after-hours day Thu 00:00 23:59
after-hours day Fri 00:00 23:59
after-hours day Sat 00:00 23:59
create cnf-files version-stamp 7960 Aug 16 2008 16:08:16
dial peer configuration which is blocked in telephoney service
dial-peer voice 7 pots
destination-pattern 900T
direct-inward-dial
port 2/0:15
prefix 00
10-07-2008 05:53 AM
can u recieve calls on those FXS ports ?
10-07-2008 06:16 AM
Yes, I can recive and dial the local and national numbers. but i couldnt dial the international calls. when i remove "no after-hours block pattern 1 900" then i am able to make international calls from FXS connected phone. if i put this "after-hours block pattern 1 900" then unable to make international call.
