Call drops after called party answers
Fikri FIRAT
Level 5
Level 5
Hi all,
We are facing a strange issue in our IP telephony system. When placing a call, the call drops right after the called party answers it. 'debug ccsip messages' provided the attached log. The customers has been continuously reporting that they have been facing the issue for a long time. The problem is not dependant on the called number type (it occurs when dialing other cities, dialing GSM numbers, etc.) Do you have any ideas? Looking forward for your support. The location uses analog lines, not PRI.
Fikri
Router Info
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
N4DIKILI uptime is 21 hours, 0 minutes
System returned to ROM by reload at 18:19:58 TR Tue Jan 22 2013
System restarted at 18:21:24 TR Tue Jan 22 2013
System image file is "flash:c2800nm-advipservicesk9-mz.124-24.T3.bin"
Cisco 2821 (revision 53.51) with 473088K/51200K bytes of memory.
Processor board ID FHK1341F2XX
2 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
12 Voice FXO interfaces
8 Voice FXS interfaces
Call Manager Info
System version: 8.0.3.23033-1
Device Info
Cisco 7942 with SCCP42.9-1-1SR1S
Harmit Singh
Hi Fikri,
I looked at the debug output and I see the gateway sends a BYE to CUCM with normal call clearing (cause value 16):
Jan 23 15:15:45.832: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:811121000@10.231.100.107:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.103.96.1:5060;branch=z9hG4bK7C2160
To: "Burak test" <811121000>;tag=56c1d08b-be7c-41a9-b496-cb41dcbe340e-147132898
Date: Wed, 23 Jan 2013 13:15:42 GMT
Call-ID: f9f69500-ff1e27b-36edd2-6b64e70a@10.231.100.107
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1358946945
CSeq: 101 BYE
Reason: Q.850;cause=16
Content-Length: 0
++     Does this happen on every outbound call or is it intermittent?
++     Do you face any issues for incoming calls?
++     Is this a new setup or was this working fine before?
++     Can you please post the running config of this gateway?
Also, we need to see what's going on with the other call leg i.e. the one between the gateway and FXO. Kindly capture the following debugs for one outbound test call:
debug voip ccapi inout
debug vpim signal
debug voip vtsp default
debug voip vtsp session
Once the call completes, please capture the following command as well:
Show voice trace            --> The same port through which the test call went out of.
Harmit.
Hi Harmit,
Thank you for your quick support!
The problem does not happen on every outbound call,
There has been no report that it happens on incoming calls,
The setup is the same that we are using for numerous other locations (~250) which are working well.
The running-config is provided in the attachments.
I will provide the debugs that you requested as soon as possible, since the problem occurs intermittently, it will be difficult.
Fikri
Hi Fikri,
Based on the info you provided, this sounds like a problem with certain FXO lines, maybe even one (due to its intermittent nature). The debugs would help verify the same. Also, I would suggest having the FXO lines tested by plugging them directly to an analog phone and confirm if you are able to get outbound calls to work on all lines.
HTH.
Harmit.
