call drops with cause code 28 while sending fax over siptrunk
we yestarday configured router for sending fax over ip. we are able to recive the fax tone when calling to the sip channel configured for Rightfax.
but when we are sending outgoing fax it is failing with the causecode 28.
Fax server IP : 192.168.12.73
sip-server       : 10.200.7.157
Numbers alloted 2505481 to 2505489
the running config is
dial-peer voice 180 voip
description **to FAX SERVER**
destination-pattern 250548.
session protocol sipv2
session target ipv4:192.168.12.73
codec g711alaw
fax protocol pass-through g711alaw
no vad
dial-peer voice 20 voip
description ***OUT-BOUND CALLS TO PSTN***
translation-profile outgoing OUT-SIP
destination-pattern .T
progress_ind progress enable 8
rtp payload-type cisco-codec-fax-ack 111
rtp payload-type nte 97
voice-class codec 1
session target ipv4:10.200.7.157:5060
session transport udp
dtmf-relay rtp-nte
no vad
dial-peer voice 11 voip
description **Outgoing Call to SIP Trunk**
translation-profile outgoing OUT_FAX
destination-pattern 33.T
codec g711alaw
no vad
sip-ua
disable-early-media 180
sip-server ipv4:10.200.7.157:5060
The #debug voice ccapi inout  Result is
ASICO-RYD#
Jan 20 06:03:01.111: //263969/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 0 to dstCallId 0x40722
Jan 20 06:03:01.187: //263969/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
Jan 20 06:03:02.343: //263976/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Call Entry Is Not Found
Jan 20 06:03:02.347: //-1/E2278418BD54/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=5481
   ----- ccCallInfo IE subfields -----
   cisco-ani=5481
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=334631294
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jan 20 06:03:02.347: //-1/E2278418BD54/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x46B20478, Call Info(
   Calling Number=5481,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=334631294(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=20, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=263976
Jan 20 06:03:02.347: //-1/E2278418BD54/CCAPI/ccCheckClipClir:
   In: Calling Number=5481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=5481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Jan 20 06:03:02.347: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 20 06:03:02.347: :cc_get_feature_vsa malloc success
Jan 20 06:03:02.347:  cc_get_feature_vsa count is 5
Jan 20 06:03:02.347: :FEATURE_VSA attributes are: feature_name:0,feature_time:1181470208,feature_id:101595
Jan 20 06:03:02.347: //263976/E2278418BD54/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=5481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=334631294(TON=Unknown, NPI=Unknown))
Jan 20 06:03:02.351: //263976/E2278418BD54/CCAPI/cc_process_call_setup_ind:
   Event=0x469FAC70
Jan 20 06:03:02.351: //263976/E2278418BD54/CCAPI/ccCallSetContext:
   Context=0x47757BD8
   >>>>CCAPI handed cid 263976 with tag 20 to app "_ManagedAppProcess_Default"
Jan 20 06:03:02.351: //263976/E2278418BD54/CCAPI/ccCallProceeding:
Jan 20 06:03:02.355: //263976/E2278418BD54/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=11, Params=0x45B6AED4, Progress Indication=NULL(0)
Jan 20 06:03:02.355: //263976/E2278418BD54/CCAPI/ccCheckClipClir:
   Destination Pattern=33.T, Called Number=334631294, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=5481, Final Destination Flag=TRUE,
   Guid=E2278418-61FD-11E2-BD54-8C1DCA81D3CC, Outgoing Dial-peer=11
Jan 20 06:03:02.355: //263976/E2278418BD54/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=5481
   cisco-ani=5481
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=334631294
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 20 06:03:02.359: //263976/E2278418BD54/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x46B20478, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=5481,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=334631294(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=11, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jan 20 06:03:02.359: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 20 06:03:02.359: :cc_get_feature_vsa malloc success
Jan 20 06:03:02.359:  cc_get_feature_vsa count is 6
Jan 20 06:03:02.359: :FEATURE_VSA attributes are: feature_name:0,feature_time:1181470424,feature_id:101596
Jan 20 06:03:02.359: //263977/E2278418BD54/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Jan 20 06:03:02.359: //263977/E2278418BD54/CCAPI/ccCallSetContext:
   Context=0x45B6AE84
Jan 20 06:03:02.359: //263976/E2278418BD54/CCAPI/ccSaveDialpeerTag:
Jan 20 06:03:02.363: //263977/E2278418BD54/CCAPI/cc_api_call_proceeding:
   Interface=0x46B20478, Progress Indication=NULL(0)
Jan 20 06:03:02.435: //263977/E2278418BD54/CCAPI/cc_api_call_disconnected:
   Cause Value=28, Interface=0x46B20478, Call Id=263977
   Call Entry(Responsed=TRUE, Cause Value=28, Retry Count=0)
Jan 20 06:03:02.435: //263976/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Jan 20 06:03:02.435: //263977/E2278418BD54/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=263977
Jan 20 06:03:02.435: //263977/E2278418BD54/CCAPI/ccCallDisconnect:
   Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=28)
   Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28)
Jan 20 06:03:02.439: //263977/E2278418BD54/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46B20478, Tag=0x0, Call Id=263977,
   Call Entry(Disconnect Cause=28, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jan 20 06:03:02.439: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 20 06:03:02.439: :cc_free_feature_vsa freeing 466BCED0
Jan 20 06:03:02.439:  vsacount in free is 5
Jan 20 06:03:02.443: //263976/E2278418BD54/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=20, Params=0x47746940, Progress Indication=NULL(0)
Jan 20 06:03:02.443: //263976/E2278418BD54/CCAPI/ccCheckClipClir:
   In: Calling Number=2505481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=2505481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=.T, Called Number=0334631294, Digit Strip=FALSE
   Calling Number=2505481(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=0334631294(TON=Unknown, NPI=Unknown),
   Guid=E2278418-61FD-11E2-BD54-8C1DCA81D3CC, Outgoing Dial-peer=20
Jan 20 06:03:02.443: //263976/E2278418BD54/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=5481
   cisco-ani=2505481
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=0334631294
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 20 06:03:02.443: //263976/E2278418BD54/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=2505481,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=0334631294(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20, Call Count On=FALSE,
Jan 20 06:03:02.443: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 20 06:03:02.443: :cc_get_feature_vsa malloc success
Jan 20 06:03:02.443:  cc_get_feature_vsa count is 6
Jan 20 06:03:02.447: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 20 06:03:02.447: :FEATURE_VSA attributes are: feature_name:0,feature_time:1181470424,feature_id:101597
Jan 20 06:03:02.447: //263978/E2278418BD54/CCAPI/ccIFCallSetupRequestPrivate:
Jan 20 06:03:02.447: //263978/E2278418BD54/CCAPI/ccCallSetContext:
   Context=0x477468F0
Jan 20 06:03:02.447: //263976/E2278418BD54/CCAPI/ccSaveDialpeerTag:
Jan 20 06:03:02.451: //263978/E2278418BD54/CCAPI/cc_api_call_proceeding:
Jan 20 06:03:03.207: //263978/E2278418BD54/CCAPI/cc_api_call_alert:
   Interface=0x46B20478, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Jan 20 06:03:03.211: //263978/E2278418BD54/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
Jan 20 06:03:03.211: //263976/E2278418BD54/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, AlertSent=TRUE)
ASICO-RYD#
ASICO-RYD#
Jan 20 06:03:34.987: //263971/006B98E54403/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=263971
Jan 20 06:03:34.987: //263972/006B98E54403/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x46B20478, Call Id=263972
Jan 20 06:03:34.991: //263972/006B98E54403/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Jan 20 06:03:34.991: //263971/006B98E54403/CCAPI/ccConferenceDestroy:
   Conference Id=0xDCD7, Tag=0x0
Jan 20 06:03:34.991: //263971/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0xDCD7, Source Interface=0x46DC83FC, Source Call Id=263971,
   Destination Call Id=263972, Disposition=0x0, Tag=0x0
Jan 20 06:03:34.991: //263972/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0xDCD7, Source Interface=0x46B20478, Source Call Id=263972,
   Destination Call Id=263971, Disposition=0x0, Tag=0x0
Jan 20 06:03:34.991: //263971/006B98E54403/CCAPI/cc_generic_bridge_done:
Jan 20 06:03:34.991: //263971/006B98E54403/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jan 20 06:03:34.991: //263971/006B98E54403/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jan 20 06:03:34.991: //263972/006B98E54403/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Jan 20 06:03:34.999: //263971/006B98E54403/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46DC83FC, Tag=0x0, Call Id=263971,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Jan 20 06:03:34.999: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 20 06:03:34.999: :cc_free_feature_vsa freeing 466BBB68
Jan 20 06:03:34.999:  vsacount in free is 5
Jan 20 06:03:35.003: //263972/006B98E54403/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46B20478, Tag=0x0, Call Id=263972,
Jan 20 06:03:35.003: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 20 06:03:35.003: :cc_free_feature_vsa freeing 466BD8F0
Jan 20 06:03:35.003:  vsacount in free is 4
Jan 20 06:03:54.219: //263976/E2278418BD54/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x46B20478, Call Id=263976
Jan 20 06:03:54.219: //263978/E2278418BD54/CCAPI/ccCallDisconnect:
Jan 20 06:03:54.219: //263976/E2278418BD54/CCAPI/ccCallDisconnect:
Jan 20 06:03:54.223: //263976/E2278418BD54/CCAPI/ccCallDisconnect:
Jan 20 06:03:54.231: //263976/E2278418BD54/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46B20478, Tag=0x0, Call Id=263976,
Jan 20 06:03:54.231: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 20 06:03:54.231: :cc_free_feature_vsa freeing 466BCDF8
Jan 20 06:03:54.231:  vsacount in free is 3
Jan 20 06:03:54.267: //263978/E2278418BD54/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46B20478, Tag=0x0, Call Id=263978,
Jan 20 06:03:54.267: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 20 06:03:54.267: :cc_free_feature_vsa freeing 466BCED0
Jan 20 06:03:54.267:  vsacount in free is 2
Jan 20 06:03:54.775: //263970/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 9 to dstCallId 0x40721
Jan 20 06:03:54.815: //263970/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
ASICO-RYD#
ASICO-RYD#
ASICO-RYD#
ASICO-RYD#u all
All possible debugging has been turned off
ASICO-RYD#
when i modified the dial-peer 20 , the fax call matching dial-peer 11 and disconnecting with cause code 28
Please can any one help.......
17 Replies 17
I'm glad to be of help :-)
For outgoing faxes to the PSTN --> no change required. All 20 DID lines can be used.
For incoming faxes from the PSTN --> 2505499 will be the Pilot Point configured on ITSP end, which will then hunt based on the hunting algorithm configured on their end itself which DID line to send the call into your CUBE. So you will receive calls on all DID lines as well.
Harmit.
Thankyou very much Harmit,
you made my day.....
thanks a lot.
My pleasure Mohammed, happy to help :-)
Harmit.
