Call forward Busy / no answer report CUCM 7.1(3)
kevbo
Level 5
Level 5
Is there a way of producing a report that shows current call foward busy no answer destinations? We have a high turnover of staff and numbers are reallocated so old diverts are still in place.
cheers
Kev
Jaime Valencia
No, if you search CSC you can find some qrys you can run on CLI to get this, or you can simply export the info from the lines with BAT and look at it that way.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Cheers Java
I did see Bill's post on SQL queries but I dont know how to manipluate the CFWd All query for CFWd busy /no answer.
cheers
Kev
