Call Forward Issue
damiranz20
Dear Sir,
Greetings!
I have CME Version 15.0, I having a problem to forward all my call when I am not in the office.
The following is my current config to my Cisco Voice Router:
Under Telephony Service:
telephony-service
no auto-reg-ephone
em logout 0:0 0:0 0:0
max-ephones 58
max-dn 300
ip source-address 172.17.4.2 port 2000
auto assign 1 to 22
timeouts interdigit 3
timeouts ringing 60
load 7906 SCCP11.8-3-3S
load 7910 P00403020214
load 7911 SCCP11.8-3-3S
load 7960-7940 P00308000500
load 7941 SCCP41.8-3-3S
load 7945 SCCP45.8-3-3S
load 7961 SCCP41.8-3-3S
load 7965 SCCP45.8-3-3S
time-zone 31
date-format dd-mm-yy
dialplan-pattern 1 21556.. extension-length 4 extension-pattern 56..
voicemail 6000
max-conferences 8 gain -6
moh "music-on-hold.au"
web admin system name admin password admin
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
directory last-name-first
create cnf-files version-stamp 7960 Oct 21 2016 10:31:51
I want to forward my call in my Mobile if I am not in my Office.
Thanks for the help in advance,
Best regards,
Kael
7 Replies 7
Jitender Bhandari
Hi Kael,
Can you provide the complete show run.
Also are you trying to CFA, is it going out PRI.
Call the number and attach the below debug with calling \ called number
  1. debug isdn q931
  2. debug voice ccapi inout.
JB
Dear Sir,
Sh Run
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2008.12.17 17:51:32 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 31113 bytes
! Last configuration change at 15:20:56 ksa Tue Oct 25 2016 by mawad
! NVRAM config last updated at 08:16:11 ksa Tue Oct 25 2016
version 15.3
service password-encryption
hostname KSA-CCME
boot-start-marker
boot-end-marker
aqm-register-fnf
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
clock timezone ksa 2 30
network-clock-participate wic 0
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 172.17.3.1 172.17.3.2
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip dhcp pool IPPHONES
network 172.17.3.0 255.255.255.0
default-router 172.17.3.1
option 150 ip 172.17.4.2
ip domain name KSA.LOCAL
ip name-server 212.93.192.4
ip name-server 212.93.192.5
ip name-server 84.235.7.59
ip name-server 84.235.6.59
ip cef
no ipv6 cef
crypto pki trustpoint TP-self-signed-461811316
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-461811316
revocation-check none
rsakeypair TP-self-signed-461811316
crypto pki trustpoint TP-self-signed-357131640
subject-name cn=IOS-Self-Signed-Certificate-357131640
rsakeypair TP-self-signed-357131640
crypto pki certificate chain TP-self-signed-461811316
certificate self-signed 01
30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 34363138 31313331 36301E17 0D313430 31323830 33333535
375A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3436 31383131
33313630 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
B0D648EA 30327599 F8500DED 98328D94 5E9C9B61 16238DE5 B7723BCD 8C5F9A93
A6AB2D7E 6EE77725 7A7D9203 0823A56C 86819A4C 7EC7D27B 9ED64E38 6C3F6B5F
2F870867 E6104705 D06C2DA4 65348A70 B095A839 3B858357 B9329B90 4F351543
387C5664 7B40BC58 E3B47D22 8AD7B11B D1E56961 DAA3F1DE F169B5DB 6360C1B5
02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
23041830 168014D2 7FEEFD17 638D84D6 440460C0 59276931 D0C78E30 1D060355
1D0E0416 0414D27F EEFD1763 8D84D644 0460C059 276931D0 C78E300D 06092A86
4886F70D 01010505 00038181 006D1773 D5AAAECC 1B8A7023 077E21B8 A4AE7834
90A23EDC 03ECF95B A6C449B4 316EE994 EFFC5625 BD31BF93 0C07912E 342DBDC4
3CC0E316 982F7CB7 3229B94C BF8771FE 8B15671A F08874B5 A6B54E53 A8B42E8E
FFD15BE6 54C4914B 6F41E429 038BBED1 E043C2F9 6E1C6C70 F8FF2C5A FE137DE3
726681BA 8EA75CB0 06CF1A60 D3
quit
crypto pki certificate chain TP-self-signed-357131640
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
signaling forward rawmsg
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
emptycapability
no h225 h245-address facility
h225 id-passthru
h245 passthru tcsnonstd-passthru
sip
midcall-signaling block
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
voice hunt-group 1 parallel
list 5630,5631,5624,5670,5654,5644
timeout 30
pilot 2155666 secondary 5666
voice hunt-group 3 parallel
list 5603,5684,5697
timeout 30
pilot 2155688 secondary 5688
voice translation-rule 1
rule 1 /011\(.......\)/ /\1/
rule 2 /2155\(...\)/ /\1/
voice translation-rule 2
rule 1 /5......../ /0\0/
voice translation-rule 10
rule 2 /^.*\(....\)/ /\1/
voice translation-rule 11
rule 2 /^.*\(56..\)$/ /\1/
rule 3 /^.*\(....\)$/ /5678/
voice translation-profile PrefixDNIS
translate calling 2
translate called 1
voice translation-profile UnicornSTC
translate calling 11
license udi pid CISCO2911/K9 sn FCZ180560JS
hw-module pvdm 0/0
archive
log config
hidekeys
redundancy
controller E1 0/0/0
framing NO-CRC4
ds0-group 1 timeslots 1-6 type r2-digital r2-semi-compelled ani
ds0-group 2 timeslots 17-23 type r2-digital r2-semi-compelled ani
cas-custom 1
country saudiarabia use-defaults
cas-custom 2
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
tftp-server flash:P00307020200.bin
tftp-server flash:P00307020200.loads
tftp-server flash:P00307020200.sb2
tftp-server flash:P00307020200.sbn
tftp-server flash:P00403020214.bin
tftp-server flash:apps41.8-3-2-27.sbn alias apps41.8-3-2-27.sbn
tftp-server flash:cnu41.8-3-2-27.sbn alias cnu41.8-3-2-27.sbn
tftp-server flash:cvm41sccp.8-3-2-27.sbn alias cvm41sccp.8-3-2-27.sbn
tftp-server flash:dsp41.8-3-2-27.sbn alias dsp41.8-3-2-27.sbn
tftp-server flash:jar41sccp.8-3-2-27.sbn alias jar41sccp.8-3-2-27.sbn
tftp-server flash:SCCP41.8-3-3S.loads alias SCCP41.8-3-3S.loads
tftp-server flash:term41.default.loads alias term41.default.loads
tftp-server flash:term61.default.loads alias term61.default.loads
tftp-server flash:P00308000500.bin alias P00308000500.bin
tftp-server flash:P00308000500.loads alias P00308000500.loads
tftp-server flash:P00308000500.sb2 alias P00308000500.sb2
tftp-server flash:P00308000500.sbn alias P00308000500.sbn
tftp-server flash:apps11.8-3-2-27.sbn alias apps11.8-3-2-27.sbn
tftp-server flash:cnu11.8-3-2-27.sbn alias cnu11.8-3-2-27.sbn
tftp-server flash:cvm11sccp.8-3-2-27.sbn alias cvm11sccp.8-3-2-27.sbn
tftp-server flash:dsp11.8-3-2-27.sbn alias dsp11.8-3-2-27.sbn
tftp-server flash:jar11sccp.8-3-2-27.sbn alias jar11sccp.8-3-2-27.sbn
tftp-server flash:SCCP11.8-3-3S.loads alias SCCP11.8-3-3S.loads
tftp-server flash:term06.default.loads alias term06.default.loads
tftp-server flash:term11.default.loads alias term11.default.loads
tftp-server flash:apps45.8-3-2-27.sbn alias apps45.8-3-2-27.sbn
tftp-server flash:cnu45.8-3-2-27.sbn alias cnu45.8-3-2-27.sbn
tftp-server flash:cvm45sccp.8-3-2-27.sbn alias cvm45sccp.8-3-2-27.sbn
tftp-server flash:dsp45.8-3-2-27.sbn alias dsp45.8-3-2-27.sbn
tftp-server flash:jar45sccp.8-3-2-27.sbn alias jar45sccp.8-3-2-27.sbn
tftp-server flash:SCCP45.8-3-3S.loads alias SCCP45.8-3-3S.loads
tftp-server flash:term45.default.loads alias term45.default.loads
tftp-server flash:term65.default.loads alias term65.default.loads
access-list 10 permit 172.17.0.0 0.0.255.255
access-list 10 permit 192.168.1.0 0.0.0.255
control-plane
voice-port 0/0/0:1
voice-port 0/0/0:2
translation-profile outgoing UnicornSTC
voice-port 0/1/0
supervisory disconnect dualtone mid-call
no battery-reversal
cptone SA
timeouts call-disconnect 2
timeouts wait-release 2
connection plar opx 5678
caller-id enable
voice-port 0/1/1
no battery-reversal
cptone SA
caller-id enable
mgcp fax t38 ecm
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer cor custom
name private
name none
dial-peer cor list calls-allowed-all
member private
dial-peer cor list calls-internal-only
member none
dial-peer voice 1 pots
corlist outgoing calls-allowed-all
destination-pattern 9.T
port 0/0/0:2
dial-peer voice 6000 voip
destination-pattern 6000
session protocol sipv2
session target ipv4:172.17.4.5
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2 pots
incoming called-number 56..
direct-inward-dial
port 0/0/0:1
dial-peer voice 7000 voip
description AutoAttendant Prompt
destination-pattern 5678
b2bua
no call fallback
codec g711ulaw
no vad
dial-peer voice 4 pots
destination-pattern 9.0[123467]T
port 0/0/0:2
dial-peer voice 10 voip
translation-profile incoming PrefixDNIS
session transport udp
incoming called-number 2905...
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 11 voip
incoming called-number 0112155...
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 3400 voip
dtmf-relay rtp-nte
dial-peer voice 111 voip
destination-pattern 05........$
session target ipv4:10.200.7.157
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 112 voip
destination-pattern 01........$
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 113 voip
destination-pattern [2-7]......$
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 114 voip
destination-pattern ^9[^2].
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 115 voip
destination-pattern 9200.....$
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 116 voip
destination-pattern 800.......$
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 117 voip
destination-pattern 00.T
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 118 voip
destination-pattern 8[1-9].....$
dtmf-relay rtp-nte
codec g711alaw
no vad
sip-ua
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 58
max-dn 300
auto assign 1 to 22
timeouts ringing 60
time-zone 31
voicemail 6000
dn-webedit
time-webedit
transfer-pattern .T
ephone-dn 1 dual-line
number 5600
line con 0
exec-timeout 2 0
logging synchronous
login local
line aux 0
exec-timeout 2 0
logging synchronous
login local
transport output pad telnet ssh
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
exec-timeout 2 0
privilege level 15
password 7 094F471A1A0A
logging synchronous
login local
transport input all
transport output all
line vty 5 15
access-class 23 in
exec-timeout 2 0
privilege level 15
password 7 01100F175804
logging synchronous
login local
transport input ssh
scheduler allocate 20000 1000
ntp master 1
end
CME#logout
Thanks and Best regards,
Kael
Also please call the number and attach the below debug with calling \ called number
  1. debug isdn q931
JB
Where  to config that 2 commands? Thanks
below might help
http://www.cisco.com/c/en/us/support/docs/voice/h323/14081-voip-debugcalls.html#q931
https://supportforums.cisco.com/discussion/11584921/how-debug-incoming-isdn-call
JB
Dear Sir,
Any Update Please... Kindly Help me for this issue.
Appreciated with Thanks..
Dear Sir,
Just added this below Config:
Still not working my forwarding Call:
call-forward pattern .T
call-forward system redirecting-expanded
transfer-pattern .T
Any solution please....
Michael
