11-02-2016 05:57 AM - edited 03-17-2019 08:33 AM
Hi Community,
I enabled our CME GUI. Why i cannot see the SIP phones that are registered and also the DN/Extensions?.
I can only see 1 phone which is SCCP. Is this a limitation for the GUI?
My CME version is 10.5 and used version 10.5 for the GUI.
Solved! Go to Solution.
11-02-2016 06:22 AM
That's completely expected, the GUI only works for SCCP.
11-02-2016 06:22 AM
11-13-2016 12:55 AM
Hi Jaime,
Is there any official document from Cisco that I can show to the customer because they want a proof that this is a system's limitation?
Thanks.
11-13-2016 10:05 AM
I don't believe there's any doc that says that, I believe there was a bug for that as a sev 6, you can try searching for it.
