Call forwarding on huntgroup phone
I am using call manager exress system.
I want to put call forwarding on a cisco hunt group phone.
Is it possible? Please suggest me a way.
Thank you.
paolo bevilacqua
As often discussed, had your searched before asking.
No, it is not possible.
You can use voice hunt-group. but you will loose important features.
I just answered this last week and provided the link.
Your only alternative is single number reach if you want to ring an external phone.
That limitation, and how to configure SNR, is covered in the CME config guide.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
