call forwarding without setting in CUCM
could you please help me, i found some call from SIP inbound, call direct to extension 206197 but after 9 second call forwarding to 206136 without setting in CUCM and two number are not using in Hunting group
Message Details
SENDER: 10.20.0.12
GUID: E295204A-F0DB11EA-82E9C2A0-4C6778AB@10.20.0.23
MSG_LABEL: 180 Ringing
RECEIVER: [SIP-TRUE-DC] 10.20.0.23
MAC_ADDRESS: SIP-TRUE-DC
MSGTAG: 1401529978
MSG_TYPE: UCM_CTRACE
CORRELATIONID: 2,100,14,64100644.33827^10.20.13.193^*
TIMESTAMP: 2020/09/08 14:29:37.928
Detailed Sip Message
There is no SIP message to display!
Please verify the following:
1.Check if the "Enable SIP Call Processing Trace" check box in "Unified Serviceability Webpage --> Trace --> Configuration --> CM Services --> Cisco CallManager" is enabled
2.Check if the trace level is set to State Transition, Significant, Arbitrary or Detailed
Message In Log File
2020/09/08 14:29:37.817|SIPT|0|UDP|IN|10.20.0.12|5060|SIP-TRUE-DC|10.20.0.23|54782|2,100,10,1.19902439^10.20.0.23^*|1401529958|E295204A-F0DB11EA-82E9C2A0-4C6778AB@10.20.0.23|INVITE
2020/09/08 14:29:37.818|SIPT|0|UDP|OUT|10.20.0.12|5060|SIP-TRUE-DC|10.20.0.23|5060|2,100,10,1.19902439^10.20.0.23^*|1401529959|E295204A-F0DB11EA-82E9C2A0-4C6778AB@10.20.0.23|100 Trying
2020/09/08 14:29:37.821|CC|SETUP|38186994|38186995|90628295194|206197|206197
2020/09/08 14:29:37.824|CC|OFFERED|38186994|38186995|90628295194|206197|206197|SIP-TRUE-DC|SEPCC9891D1F3AA
2020/09/08 14:29:37.825|SIPL|38186995|TCP|OUT|10.20.0.12|5060|SEPCC9891D1F3AA|10.20.13.193|51733|2,100,10,1.19902439^10.20.0.23^*|1401529960|b4a8c00-f57132e1-1ad281d-c00140a@10.20.0.12|INVITE
2020/09/08 14:29:37.833|SIPL|38186995|TCP|IN|10.20.0.12|5060|SEPCC9891D1F3AA|10.20.13.193|51733|2,100,14,64100644.33826^10.20.13.193^*|1401529966|b4a8c00-f57132e1-1ad281d-c00140a@10.20.0.12|100 Trying
2020/09/08 14:29:37.926|SIPL|38186995|TCP|IN|10.20.0.12|5060|SEPCC9891D1F3AA|10.20.13.193|51733|2,100,14,64100644.33827^10.20.13.193^*|1401529977|b4a8c00-f57132e1-1ad281d-c00140a@10.20.0.12|180 Ringing
2020/09/08 14:29:37.928|SIPT|38186994|UDP|OUT|10.20.0.12|5060|SIP-TRUE-DC|10.20.0.23|5060|2,100,14,64100644.33827^10.20.13.193^*|1401529978|E295204A-F0DB11EA-82E9C2A0-4C6778AB@10.20.0.23|180 Ringing
2020/09/08 14:29:46.063|CC|SETUP|38186994|38187020|90628295194|206197|206136
2020/09/08 14:29:46.069|SIPL|38187020|TCP|OUT|10.20.0.13|5060|SEPCC9891D1CAC6|10.20.13.197|51263|3,100,14,20999950.3297^10.20.0.17^*|197003362|10a7d680-f57132ea-2f05bc-d00140a@10.20.0.13|INVITE
2020/09/08 14:29:46.069|SIPL|38187020|TCP|OUT|10.20.0.13|5060|TCT206136|10.20.0.17|5060|3,100,14,20999950.3297^10.20.0.17^*|197003363|10a7d680-f57132ea-2f05bd-d00140a@10.20.0.13|INVITE
2020/09/08 14:29:46.070|CC|OFFERED|38186994|38187020|90628295194|206197|206136|SIP-TRUE-DC|SEPCC9891D1CAC6
2020/09/08 14:29:46.071|SIPL|38186995|TCP|OUT|10.20.0.12|5060|SEPCC9891D1F3AA|10.20.13.193|51733|3,100,14,20999950.3297^10.20.0.17^*|1401530600|b4a8c00-f57132e1-1ad281d-c00140a@10.20.0.12|CANCEL
2020/09/08 14:29:46.075|SIPL|38186995|TCP|IN|10.20.0.12|5060|SEPCC9891D1F3AA|10.20.13.193|51733|2,100,14,64100644.33828^10.20.13.193^*|1401530601|b4a8c00-f57132e1-1ad281d-c00140a@10.20.0.12|200 OK
2020/09/08 14:29:46.076|CC|RELEASE|38186995|0|0
2020/09/08 14:29:46.077|SIPL|38186995|TCP|IN|10.20.0.12|5060|SEPCC9891D1F3AA|10.20.13.193|51733|2,100,14,64100644.33829^10.20.13.193^*|1401530602|b4a8c00-f57132e1-1ad281d-c00140a@10.20.0.12|487 Request Cancelled
2020/09/08 14:29:46.077|SIPL|38186995|TCP|OUT|10.20.0.12|5060|SEPCC9891D1F3AA|10.20.13.193|51733|2,100,14,64100644.33829^10.20.13.193^*|1401530603|b4a8c00-f57132e1-1ad281d-c00140a@10.20.0.12|ACK
2020/09/08 14:29:46.083|SIPL|38187020|TCP|IN|10.20.0.13|5060|SEPCC9891D1CAC6|10.20.13.197|51263|3,100,14,21233652.657^10.20.13.197^*|197003367|10a7d680-f57132ea-2f05bc-d00140a@10.20.0.13|100 Trying
2020/09/08 14:29:46.181|SIPL|38187020|TCP|IN|10.20.0.13|5060|SEPCC9891D1CAC6|10.20.13.197|51263|3,100,14,21233652.658^10.20.13.197^*|197003371|10a7d680-f57132ea-2f05bc-d00140a@10.20.0.13|180 Ringing
2020/09/08 14:29:46.184|SIPT|38186994|UDP|OUT|10.20.0.12|5060|SIP-TRUE-DC|10.20.0.23|5060|3,100,14,21233652.658^10.20.13.197^*|1401530610|E295204A-F0DB11EA-82E9C2A0-4C6778AB@10.20.0.23|UPDATE
2020/09/08 14:29:46.187|SIPT|38186994|UDP|IN|10.20.0.12|5060|SIP-TRUE-DC|10.20.0.23|54782|2,100,10,1.19902451^10.20.0.23^*|1401530612|E295204A-F0DB11EA-82E9C2A0-4C6778AB@10.20.0.23|200 OK
2020/09/08 14:29:48.255|SIPL|38187020|TCP|IN|10.20.0.13|5060|TCT206136|10.20.0.17|5060|3,100,14,21381534.1693^10.20.0.17^*|197003469|10a7d680-f57132ea-2f05bd-d00140a@10.20.0.13|200 OK
2020/09/08 14:29:48.257|SIPL|38187020|TCP|OUT|10.20.0.13|5060|SEPCC9891D1CAC6|10.20.13.197|51263|3,100,14,21381534.1693^10.20.0.17^*|197003471|10a7d680-f57132ea-2f05bc-d00140a@10.20.0.13|CANCEL
2020/09/08 14:29:48.264|SIPT|38186994|UDP|OUT|10.20.0.12|5060|SIP-TRUE-DC|10.20.0.23|5060|3,100,14,21381534.1693^10.20.0.17^*|1401530756|E295204A-F0DB11EA-82E9C2A0-4C6778AB@10.20.0.23|200 OK
2020/09/08 14:29:48.264|SIPL|38187020|TCP|OUT|10.20.0.13|5060|TCT206136|10.20.0.17|5060|3,100,14,21381534.1693^10.20.0.17^*|197003472|10a7d680-f57132ea-2f05bd-d00140a@10.20.0.13|ACK
2020/09/08 14:29:48.264|SIPL|38187020|TCP|OUT|10.20.0.13|5060|TCT206136|10.20.0.17|5060|3,100,14,21381534.1693^10.20.0.17^*|197003473|10a7d680-f57132ea-2f05bd-d00140a@10.20.0.13|SUBSCRIBE
2020/09/08 14:29:48.267|SIPT|38186994|UDP|IN|10.20.0.12|5060|SIP-TRUE-DC|10.20.0.23|54782|2,100,10,1.19902454^10.20.0.23^*|1401530757|E295204A-F0DB11EA-82E9C2A0-4C6778AB@10.20.0.23|ACK
2020/09/08 14:29:48.290|SIPL|38187020|TCP|IN|10.20.0.13|5060|SEPCC9891D1CAC6|10.20.13.197|51263|3,100,14,21233652.660^10.20.13.197^*|197003475|10a7d680-f57132ea-2f05bc-d00140a@10.20.0.13|200 OK
2020/09/08 14:29:48.292|SIPL|38187020|TCP|IN|10.20.0.13|5060|SEPCC9891D1CAC6|10.20.13.197|51263|3,100,14,21233652.661^10.20.13.197^*|197003476|10a7d680-f57132ea-2f05bc-d00140a@10.20.0.13|487 Request Cancelled
2020/09/08 14:29:48.293|SIPL|38187020|TCP|OUT|10.20.0.13|5060|SEPCC9891D1CAC6|10.20.13.197|51263|3,100,14,21233652.661^10.20.13.197^*|197003477|10a7d680-f57132ea-2f05bc-d00140a@10.20.0.13|ACK
2020/09/08 14:29:48.375|SIPL|38187020|TCP|IN|10.20.0.13|5060|TCT206136|10.20.0.17|5060|3,100,14,21381534.1694^10.20.0.17^*|197003490|10a7d680-f57132ea-2f05bd-d00140a@10.20.0.13|200 OK
2020/09/08 14:29:48.391|SIPL|38187020|TCP|IN|10.20.0.13|5060|TCT206136|10.20.0.17|25693|3,100,14,20999950.3299^10.20.0.17^*|197003494|10a7d680-f57132ea-2f05bd-d00140a@10.20.0.13|NOTIFY
2020/09/08 14:29:48.395|SIPL|38187020|TCP|OUT|10.20.0.13|5060|TCT206136|10.20.0.17|25693|3,100,14,20999950.3299^10.20.0.17^*|197003496|10a7d680-f57132ea-2f05bd-d00140a@10.20.0.13|200 OK
2020/09/08 14:31:15.985|SIPT|38186994|UDP|IN|10.20.0.12|5060|SIP-TRUE-DC|10.20.0.23|54782|2,100,10,1.19902563^10.20.0.23^*|1401537256|E295204A-F0DB11EA-82E9C2A0-4C6778AB@10.20.0.23|BYE
2020/09/08 14:31:15.989|SIPL|38187020|TCP|OUT|10.20.0.13|5060|TCT206136|10.20.0.17|5060|2,100,10,1.19902563^10.20.0.23^*|197009148|10a7d680-f57132ea-2f05bd-d00140a@10.20.0.13|BYE
2020/09/08 14:31:15.989|SIPT|38186994|UDP|OUT|10.20.0.12|5060|SIP-TRUE-DC|10.20.0.23|5060|2,100,10,1.19902563^10.20.0.23^*|1401537257|E295204A-F0DB11EA-82E9C2A0-4C6778AB@10.20.0.23|200 OK
2020/09/08 14:31:15.997|CC|RELEASE|38186994|38187020|16
Do you have a pickup group configured?
If I'm reading your post correctly you have this particular DN presented on several devices as a shared line.  Do those devices ring?  You say the call rings on 206136 "at the same time" so that suggests either Pickup Group or Mobility is configured.
TONY SMITH
You'll need to explain the call flow that you have configured in CUCM, for example when a call comes in from the SIP provider what's the first thing it matches?  Hunt Pilot?  Translation Pattern? DN?
You could have a quick look with Dialed Number Analyser if you're finding your way around the system.  Go to the Publisher IP address but with /dna on the path for example 10.10.10.10/dna   Select Trunks from the Analysis menu, find your SIP trunk and put in your whateven number the SIP trunk presents that should route on to 206197.
The number 206197 will match with translation pattern 02783xxxx (02783-6197) replace with last 4 digits
i found 206197  setting fwd to 206071 but this call alerting to number 206136 at the same time
Please find analyzer results
Results Summary
Calling Party Information
Calling Party = 90628295194
Partition =
Device CSS = CSS_Inbound
Line CSS =
AAR Group Name =
AAR CSS =
Dialed Digits = 027836197
Match Result = RouteThisPattern
Matched Pattern Information
Pattern = 206197
Partition = PT_Internal
Time Schedule =
Called Party Number = 206197
Time Zone = Asia/Bangkok
Call Classification = OnNet
InterDigit Timeout = NO
Device Override = Disabled
Outside Dial Tone = NO
Call Flow
TranslationPattern :Pattern= 02783XXXX
Partition = PT_Translation-Pattern
Positional Match List = 206197
Calling Party Number = 90628295194
PreTransform Calling Party Number = 90628295194
PreTransform Called Party Number = 027836197
Calling Party Transformations
External Phone Number Mask = NO
Calling Party Mask =
Prefix =
CallingLineId Presentation = Default
CallingName Presentation = Default
ConnectedParty Transformations
ConnectedLineId Presentation = Default
ConnectedName Presentation = Default
Called Party Transformations
Called Party Mask = 20XXXX
Discard Digits Instruction = None
Prefix =
Called Number = 206197
Directory Number :DN= 206197
TypeCFACSSPolicy = Use System Default
Call Classification = Unknown
Forwarding Information
Forward All : DN = VoiceMail = No CSS =
Forward Busy
Internal : DN = 206071 VoiceMail = No CSS = CSS_Internal
External : DN = 206071 VoiceMail = No CSS = CSS_Internal
Forward No Answer
Forward No Coverage
Internal : DN = VoiceMail = No CSS =
External : DN = VoiceMail = No CSS =
Forward Unregistered
CFDF : DN = VoiceMail = No CSS =
Pickup Group Number = 60001012
Device :Type= Cisco Dual Mode for iPhone
Device Status = UnKnown
Device Name = TCT206197
Ignore Presentation Indicators = Disabled
Logged Into Hunt Groups = Enabled
Alerting Name = Phatcharee C. 206197
Dual Mode = Enabled
Do Not Disturb(DND)
DND Status = Disabled
DND Option = Call Reject
DND Incoming Call Alert = Disable
Automated Alternate Routing (AAR)
AAR Group Name =
AAR Calling Search Space =
AAR VoiceMail Status = Disabled
AAR Destination Mask =
AAR Prefix Digits =
Device :Type= Cisco Dual Mode for Android
Device Name = BOT206197
Dual Mode = Enabled
Do Not Disturb(DND)
AAR Group Name =
AAR Prefix Digits =
Device :Type= Cisco 8841
Device Status = Registered
Device Name = SEPCC9891D1F3AA
Alerting Name = 206197
Dual Mode = Disabled
Do Not Disturb(DND)
DND Option =
AAR Group Name =
AAR Prefix Digits =
Alternate Matches
Note: Information Not Available
Thanks for your help Tony , I have configured visual alert on call pickup function so this call alert to two number at the same time.
