Call Fowarding
dtom
Beginner
Beginner
We are currently running CUCM 7.0.1.
I have a phone A (12345) that is setup to forward to phone B (12340) here are the settings:
Phone A
Call Forarward Settings          Voice Mail          Destination
Forward Busy Internal                                        12340
Foward Busy External                                        12340
Forward No Answer Internal                                12340
Forward No Answer External                               12340
Forward Unregistered Internal                              12340
Forward Unregistered External                             12340
Phone B
Forward Busy Internal                    x
Foward Busy External                    x
Forward No Answer Internal            x
Forward No Answer External          x
Forward Unregistered Internal         x
Foward Unregistered External         x
Foward No Coverage Internal           x
Foward No Coverage External          x
Forward Ungegistered Internal         x
Forward Unregistered External         x
When phone A receives a call and it is unanswered the call is fowarded to phone B.  If the call is not ansewred by phone B, the call goes to Voice Mail.  Is there any way for this call to either not go to Voice Mail (keep on ringing) or to forward back to phone A?
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
The only special rule for CF settings is for CFA.
There is no way to configure the phone to keep ringing and setting it back to the other phone causes a loop.
What you could try are line groups with those phones so you can ring back to A one last time.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Recognize Your Peers
