Call Handler on Unity 4.0 caller input changes by owners.
coconino1969
Hello all,
Unity 4.00Build 4.0(5)
CUCM 7.1
Is there a way to allow call handler owners to change the caller input not just the greetings?
William Bell
I don't believe this is possible via the TUI. I assume you are talking about changing the IVR options. You would need to do that via the web portal. You can grant limited permissions to the admin GUI. I did a write up on this a while ago:
http://www.netcraftsmen.net/resources/blogs/adding-unity-saweb-administrative-accounts-using-grantunityaccess-and-cos.html
Of course, if I am barking up the wrong tree, I apologize.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
William Bell
HTH.
Bill
Confirm.  You cannot change Caller Input options via Greetings Administrator / TUI.  You would need to use the SA for this.  Check out Bill's guide for applying limited permissions to Unity SA.  That's your best bet outside of sharing the UnityAdmin credentials (not recommended) or configuring a full blown admin account that is independent of subscriber accounts for Call Handler owners.
Hailey
Please rate helpful posts!
I believe that's what I will have to do.
Thanks for the quick response guys.
Thanks again.
