Call is not routed towards IP Phone end user
ali.raza0407
Dear all,
I have installed a PRI on a voice gateway router. I made the following configurations on a router to route the incoming calls towards IP Phone users.
card type e1 0 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
controller E1 0/0/0
pri-group timeslots 1-31 voice-dsp
interface Serial0/0/0:15
no ip address
encapsulation ppp
isdn switch-type primary-net5
isdn incoming-voice voice
no fair-queue
ip forward-protocol nd
ial-peer voice 100 voip
destination-pattern 1...
session target ipv4:192.168.100.2
dial-peer voice 20 pots
destination-pattern .T
incoming called-number 1...
port 0/0/0:15
If we made a call from PRI local netwrok vendor. Tham call properly towards IP Phone users. But if we made a call other than local network. e.g from mobile or other PSTN network than call doen't route towards a users, depiste of that we only hear a single tone. I also attached the debug file.
I enable followig debugs.
What is the problem? and what is the solution of this problem. If you require further details than I am also ready to share that.
Best Regards,
Ali Raza
11 Replies 11
acampbell
Ali,
Can you try adding this lines to the dial peers
direct-inward-dial
dial-peer voice 100 voip
incoming called-number .
dtmf-relay h245-alphanumeric
Alex
Regards, Alex. Please rate useful posts.
Hi Alex,
By adding thesee commands, we hear the following tape.
All lines are busy.
If you have any solution than please tell me.
Best Regards,
Ali Raza
Ali Raza
Can you try adding
no ip address
encapsulation ppp
no fair-queue
isdn overlap-receiving
isdn overlap-receiving T302 2000
Alex
Hi Alex
This doesn't resolve the problem and it also showing that all lines are busy.
Best Regards,
Ali Raza
Ali Raza
Can you run
debug isdn q931
make a new call and post output
Alex
Hi Alex,
Please find the attach debug results.
*Oct 12 11:21:05.441: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0086
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838A
Exclusive, Channel 10
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x0083, '04235761281F'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '61010'
Plan:ISDN, Type:Unknown
*Oct 12 11:21:05.441: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x8086 callID = 0x0088 switch = primary-net5 interface = User
*Oct 12 11:21:05.445: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8086
*Oct 12 11:21:05.445: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x8086
*Oct 12 11:21:05.517: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x0086
*Oct 12 11:21:05.517: %ISDN-6-CONNECT: Interface Serial0/0/0:9 is now connected to 04235761281F N/A
*Oct 12 11:21:24.381: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x0086
Cause i = 0x8090 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
*Oct 12 11:21:24.381: %ISDN-6-DISCONNECT: Interface Serial0/0/0:9  disconnected from 04235761281F , call lasted 18 seconds
*Oct 12 11:21:24.385: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x88
*Oct 12 11:21:50.445: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x8086
*Oct 12 11:21:50.469: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0086
Best Regards,
Ali Raza
Ali Raza.
Here is the problem
Your dial peer is looking to match only the 1010
So lets try adding
voice translation-rule 1
!###THIS TRANLATES I/C DIGITS
rule 1 /^[2-9]1/ /1/
Rule 2 /^1/ /1/
Voice translation-profile INCOME-DDI
translate called 1
voice-port 0/0/0:15
translation-profile incoming INCOME-DDI
Please try this and retest.
Let us know how it went
Alex
Hi Alex,
I try to do that but it doesn't resolve the problem. I already talked with PRI provider that we are also recieving digit 6 with our Extension numbers. At once they changed the configurations and 6 was not displaying with called number but still problem was not resolved. You can see in my first post. I also attach debug with that. Can you see anything else on debugs that I attach on first post. Also I have CUCM7.1(5) in a cluster.
Best Regards,
Ali Raza
Ali Raza,
I messed up with my original translation
Can you ammend the translation to
Rule 2 /^1/ /1/
This should work
Regard
Alex
Hi Alex,
Problem still not resolved.
Best Regards,
Ali Raza
Ali Raza,
Now we have the translations added.
Can we have a new call with a new debug isdn q931
Can we also have a show run
Alex
