07-06-2012 05:24 AM - edited 03-16-2019 12:03 PM
Dear Support,
I need to implement a ip telephony with call manager express with voice, voicemail, video etc etc.
i will use cisco router 2951 with Cisco Unity Express with 50 Ip phones.
i will also 1 3750 switch and others Switch 2960 for access devices
My question is i don't have ntp server in my organisation,
What can i do? it's the core switch (3750) can be ntp server for all others switches and router?
Where can i found the peer server to sync my CUCM router?
Thanks in advance.
Solved! Go to Solution.
07-08-2012 09:54 AM
Does any of this work so far? I see that you have a 2951 CME router from your top post but your running an IOS (c3845-ipvoicek9-mz.124-18.bin) from a 3845 router on it. When I checked the Cisco site for that c3845 IOS, it doesn't show the 2951 model as one that it works on. Am I wrong?
07-08-2012 09:58 AM
Hi Ted,
Now i'm at home making a lab with a cisco 3845 router, 2951 is for the near future for a client.
07-08-2012 10:06 AM
Can't you try to put these two files back on the flash exactly where they are supposed to be so that when you create the CNF again it will be able to delete them? If they were already on the flash you can recover them if you havn't "squeezed" the flash to permanatly delete them.
Error deleting flash:SEPDEFAULT.cnf (File not found)
%Error deleting flash:XMLDefault.cnf.xml (File not found)
07-08-2012 10:23 AM
I copied the both files from system:/its to flash:
when i created the cn-files, no error message, but the systeme delete them from the flash:
07-08-2012 12:56 PM
So will that work for you now? I'm just curious, what are you doing for a dial plan? Are you still building the config?
07-08-2012 01:29 PM
The config work, i have 3 ip phones numbers 100, 101 and 102, i call any extensions without problems
Only the cn-files that are not in the flash:
when i copy these files from systeme:/its to flash:, when the router reboot, thses files disapeared.
Regars
07-09-2012 03:09 AM
I sent you a private message that might help you out. Check it out..
07-09-2012 03:15 AM
how and where to see the private message
