Call manager - ISR voice router or Buisness edition for 450 ip phones
adeebtaqui
Level 4
Level 4
Greetings,
I would like to know if we can deploy ISR 4551V as call manager instaed  of buisness edition?
When will ISR as a solution be sufficient/ideal?
Jaime Valencia
I suggest you discuss this with a local Cisco partner with UC specializations, and explain your needs, goals, future growth, etc. So they can propose the best solution based on your requirements.
java
if this helps, please rate
You can deploy it as CME but not as CUCM unless you get UCS-E card to
deploy CUCM on ISR4k. For the number of phones listed, here is the sizing
table.
able 1. IP Phone Support per Platform
Platform
Maximum Number of Phones
Cisco 881 and 887VA Integrated Services Routers
Cisco 2901 Integrated Services Router
35
Cisco 2911 Integrated Services Router
50
Cisco 2921 Integrated Services Router
100
Cisco 2951 Integrated Services Router
150
Cisco 3925 Integrated Services Router
250
Cisco 3945 Integrated Services Router
350
Cisco 3925E Integrated Services Router
400
Cisco 3945E Integrated Services Router
450
Cisco 4321 Integrated Services Router
50
Cisco 4331 Integrated Services Router
100
Cisco 4351 Integrated Services Router
250
Cisco 4431 Integrated Services Router
350
Cisco 4451-X Integrated Services Router
450
Refer to
https://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-communications-manager-express/datasheet-c78-737647.html
***** remember to rate useful posts
